DIY puddle light led
Old 01-14-13 | 05:26 AM
  #46
Daniely30's Avatar
Daniely30
Originally Posted by 0mghi2u
when putting it back together just make sure the puddle light housing is in the correct place and the turn signal housing piece put back in the correct spot.. then put the black cover piece back on and make sure it all fits in without gaps.. if there is a slight gap on top and outer side towards the led turn signal ur fine cuz when you screw it in the gap will close up.. the puddle light housing has this white tab and the black cover housing has a opening for the black tab just make sure the white tab fits inside the black cover housing before tightening it all up... then when all done push the bottom mirror back in place first then the tops..and your all done.. ENJOY. hope this helped...
Amazing post. Great detail. Thanks. I will get to work on this.
Old 01-18-13 | 09:34 PM
  #47
HizGSF's Avatar
HizGSF
Is there a better way to pop off the mirror? I tried several times and stopped. I must have fat fingers and scared that I might break something.
Old 01-18-13 | 10:01 PM
  #48
Vizzy's Avatar
Vizzy
Tell me about it I've tried it several times tonight and couldn't get the mirror off the clip. I tried with alot of force and still nothing
UZS160 (02-26-20)
Old 01-19-13 | 02:09 AM
  #49
onexcite's Avatar
onexcite
This is the only way: put all 4 of your finger behind the back of the mirror and pulling it out. Do it from the outer side first. You only need one clip came off first and the rest just bread & butter.
Old 01-19-13 | 04:10 PM
  #50
HizGSF's Avatar
HizGSF
Finally, I got it done. It was very painful on the finger tips trying to release the clips, but it is down.
Old 01-19-13 | 07:27 PM
  #51
Vizzy's Avatar
Vizzy
yes very painful on the finger tips but i managed to get mine done today as well...mine had a bunch of glue holding on the mirror as well.
Old 03-25-13 | 09:48 PM
  #52
RTSM's Avatar
RTSM
Great, thank you for the post. Would anyone who is a previous 2011-2012 owner know if this is the same for these model years?
Thanks all.
Old 04-05-13 | 01:04 PM
  #53
yumseyo's Avatar
yumseyo
Default does anyone know if this is the same for the 2013 ES 300h?
Thanks all.
Does anyone know if the mirror mounts the same for the 2013 ES 300 h or ES 350 as well?
Old 04-05-13 | 01:19 PM
  #54
onexcite's Avatar
onexcite
It should be the same.
Old 04-06-13 | 11:47 AM
  #55
faifai83's Avatar
faifai83
Before and after photos!
Attached Thumbnails DIY puddle light led-img_3296.jpg   DIY puddle light led-img_3295.jpg
BrotherLuv (07-21-20)
Old 04-07-13 | 09:23 PM
  #56
LexFather
Guest
Posts: n/a
Great work, need to do this ASAP
Old 04-08-13 | 10:32 PM
  #57
larryinWA's Avatar
larryinWA
I missed something. I still have about 10 days until my car arrives, so I'm not sure why you wanted to change bulbs. Is it to add color, brighter lighting, less energy consumption, or something else?
Old 04-09-13 | 02:00 AM
  #58
onexcite's Avatar
onexcite
People prefer modern look white LED bulb than yellow filament, also less heat & energy consumption.
Old 04-09-13 | 09:40 PM
  #59
larryinWA's Avatar
larryinWA
This will be my first DIY project.
I'm watching the cargo ship coming in from the Pacific Ocean to Portland, oregon with my car tonight, via The MarineTraffic app on my phone. Should be unloading it in the morning. It's heading down the Columbia river now.
Old 04-09-13 | 10:24 PM
  #60
onexcite's Avatar
onexcite
My guess you will sleepless for a few days.....
You should go to the port watch them unload your car, make sure they treat her right. :-D
