DIY puddle light led
#109
The Sylvania will fit mirror puddle, trunk, mirror visor.
#110
Just got one Sylvania from AutoZone, they only had 1 in stock, 9.99, changed the trunk and the difference is huge. Thanks guys. I'll have to get 2 more for the mirrors.
#112
Guys,
tried to get to the mirror and it seems impossible. The clip does not seem to have any tabs that are moving, I can reach it but it feels really solid and no part of it seems to release. Any advise?
#113
Trust me, it's scary as hell. You have to tilt the mirror towards the car then put your finger behind the glass and pry carefully off. I repeat it's not fun but it works. I still haven't gotten to the pass. mirror since I did the driver side in July. I blame trauma (and laziness).
#114
The Sylvania does work great in the trunk because the bulb is facing down.
#115
As far as I know it's not the same bulb. I am not too sure what size bulb it uses though.
#116
Yea I just pulled gently (but firmly!) and each of the four will pop off. I didn't pry open any of the clips but you might be able to do it with a long flathead screwdriver to get the first one off. Once one is off it's easier to get more of your fingers behind the glass to pry off the rest.
#117
i just gave this several times and wow is that tab hard to release. I'm going to try what yardie did and try pulling it off. Hope nothing breaks..
Updated: Took Yardie's method and it worked like a charm even thought he first mirror took an hour to get off. Yanking it off is definitely easier than trying to pull the tabs.
#118
in the bright side, once u bite your teeth and pull one tab out, like the rest said, 3 tabs come off like butter. the people in the thread said pull or push the tab but the way i liked it is literally try to stick your index tip in between the 2 tabs like hotdog and try to carefully pull it out. that's how i did it for both sides and come off real easy. i am going to tell you tho. get ready for some EXTREME pain.
after you are done, you will look at the puddle light and smile and smoke a ciggarate and feel accomplished.
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
#119
I haven't seen any pictures of the inside, after the mirror is out. Did I miss it, or maybe someone could post a picture. I'd like to see what these tabs look like before I start pulling. Thanks in advance ...
#120
The first page has detailed pictures of the process and shows the "tabs". I did both last week, but I did not resort to trying to pop the tabs off. I gently tugged and pulled on the mirror until the tabs were off one at a time.
