LED Reverse Lights
Old 01-14-13, 06:40 PM
Vizzy
Vizzy's Avatar
Default LED Reverse Lights
I just took delivery on a 2013 GS AWD today just sold my 2011 M37x havnt even had the GS for more then 24 hrs and im already itching to mod it lol. Im wondering if its possible to replace the stock halogen reverse lights with LEDs? Also i tried looking up which bulb type on the sylvania website and its not letting me choose 2013 for vehicle year. Has anyone done this mod yet?
Old 01-14-13, 07:18 PM
mush
mush's Avatar
congrats... no idea about the LED, but it can be done
Old 01-14-13, 07:40 PM
bigblack06
bigblack06's Avatar
Yep, it is I already ordered mine from VLEDS, the bulb is 921 same as the 3rd gen GS. Congrats on getting into a real car and getting rid of that infiniti.
Old 01-14-13, 08:37 PM
Vizzy
Vizzy's Avatar
thanks i felt the same way as i was driving away today lol...which bulb did you order? i havnt pulled the trunk liner off to see how much room we have to work with. just worried about the bulb not fitting into the tail light housing
also i want to order all my LEDs from Vleds but theyre sold out of the flank bulbs and i need those for the doors and mirrors...only bulb i can order at this point is the trunk and reverse light
Old 01-14-13, 08:56 PM
sydtoosic
sydtoosic's Avatar
at the risk of sounding like a blooming idiot, i thought all our lights excluding the HID HLs... were in fact LED.
Old 01-15-13, 02:32 AM
onexcite
onexcite's Avatar
The reverse bulb is 921. If LED won't get you enough the lumen output then try mini 15W HID kit for reverse.
Old 01-15-13, 05:39 AM
Mi1lion
Mi1lion's Avatar
@ syd- Nope.. The trunk, reverse, visor, turn signal, and puddle lights are all halogen. Sucks doesn't it. For a $60K car you'd think ALL the lights would be a crisp white 5k LED. But as a relative who works for Audi corporate told me "If ALL the lights were LED, then some people would go outta business."
Old 01-15-13, 06:24 AM
Vizzy
Vizzy's Avatar
I think the 921 bulbs from VLEDs should be bright enough. I'm just worried if the bulb will fit into the tail light housing. I had HID reverse lights before on my 3G TL just didn't like waiting for the bulbs to warm up it takes too much time. So I installed LEDs reverse lights on my previous M and the visibility was good due to I also had led plate lights so that helps
Old 01-15-13, 07:01 AM
bigblack06
bigblack06's Avatar
I had the same problem I tried to switch my cree bulbs over from my old GS and they wouldn't fit. Actually for the doors they are LED's I think someone changed them but not sure as I'm pretty sure they are LED's in there. So I got these ones.
http://www.vleds.com/bulb-number/921...23-1-pair.html
Old 01-15-13, 07:05 AM
bigblack06
bigblack06's Avatar
This the exact same answer I got. I know BMW has made most of there lights LED now including turn signal.
Old 01-15-13, 07:14 AM
ronfsp
ronfsp's Avatar
I bought this from AliExpress for my reverse light.
http://www.aliexpress.com/snapshot/212465762.html
Found similar ones at iJDMTOYS.COM, but they r more expensive!
http://store.ijdmtoy.com/High-Power-...led-sku337.htm
Found this goodies at iJDMTOYS.COM, thought u might be interested too. I already ordered mine
http://store.ijdmtoy.com/Lexus-IS-ES...p/lexus-s8.htm
Old 01-15-13, 07:26 AM
yardie876
yardie876's Avatar
Nice find. I want to see a comparo between stock and these. I've been thinking going hid but not sure.
Old 01-15-13, 07:57 AM
ronfsp
ronfsp's Avatar
HID generates more heat. Dunno if there is any long term effect on the plastic covers on the rear light cover...
Old 01-15-13, 08:14 AM
SoCal1984
SoCal1984's Avatar
A couple of before and after pics would be very helpful once you are ready to install. A picture DIY post would be very helpful also. I will stay posted for more on this.
Old 01-15-13, 12:23 PM
onexcite
onexcite's Avatar
I went with the Cree LED for reverse on my 4GS but the light pattern output and the cree projector won't do any good. The reason because the socket of the reverse lights housing was design for halogen bulbs (sit higher closer to the edge not in the middle of housing) and using the reflector housing to spread out the light. When you mount the CREE LED it won't sit in the middle of the housing therefore the cree projector will project the light into the edge of the housing.
Bottom line LED in reverse won't give any good light output for reverse then I had no choice but HID. So far the kit warm up within 5 seconds and give me enough light output and no melting/heat issue. By the time all the notification messages on the 4GS's navigation screen disappear, the hid give enough lights output.
If using the Cree LED make sure you guys tape/secure it to the socket using electric tape otherwise it will come lose due to heavy bigger bulbs, vibration and trunk slamming down.
On my other car, Cree LED reverse sit in the middle of housing and the output are bright enough.
Quick Reply: LED Reverse Lights
