Quickly Turn On/Off A/C
This brings up a good question. How do you guys have your two screens set up? I personally leave Media on the big screen all the time and climate on the right smaller screen all the time. This setup seems to be the most efficient setup for me.
Obviously if I am using the nav which is rare I have the map on the big screen.
great work guys.
i should've been more clear with my question. i knew about turning off the a/c via the off button but it seems that i would still have to go through the screen to turn it back on. i was hoping to have a button function to easily just turn on and off the a/c
my situation is that it is colder in the morning and then in the afternoon, i would like to turn the a/c back on for a bit easily.
Oh well, am I the only one that keeps it ON all the time and gets the blame
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
great work guys.
got you... press auto button (above the off button) once to engage the A/C, to turn off you hit the same auto button twice, but i think it also alters your circ. mode. i've figured out a couple of ways to operate the A/C. i don't do manuals... i'd rather buy a novel and read it.
I personally just leave it on AUTO.
Press "Auto" (For Fan)
Go into Climate, Disable "A/C"
Set to Circulate or Recirculate for "A/C off" and set to "Auto Circulate/Recirculate" for "A/C On"
you can actually turn off the AC via the off button and then hit the button with the larger fan on it to get some air. once you hit the fan button your temp numbers and fan speed will display and you just have to set it with the arrows... but the AC will still be off. i never go into the climate menu unless i want to activate the heated windshield or the clean air filtration thingamajig. or maybe if my feet are cold and i set the heat to warm up my little toes.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
i think people are getting confused with a/c vs fan functions. the auto button seems to turn the fan back on. if you previously had the a/c on, it will turn that on too.
what i wanted to do was have the fan on the whole time but quickly turn on/off the a/c.
Have a look at the photos that I posted above.
K-Bud
GX - 1st Gen (2003-2009)
02-26-06 09:43 AM
