Tire pressure
Tire pressure
i know there are a few threads, but they were started a while ago and want to see what psi you guys run the longer you have the car.
right now my car comes to about 35F/36R PSI when hot.
I'm running a little low at 34 psi warmed up. Stupid question but should I just fill it with air or fill it with nitrogen at the dealership? (which iirc is what they're filled with)
i got mixed reactions on the nitro, the majority says it doesn't make to much of a difference... if any.
Air is 71% nitrogen anyway
When I drove away from the dealer, the psi of my tires were set at 30!! Two days after I went back to the dealer only because I got the warning light for one tire which was set differently-28!! So, finally they set them to 33psi. And from what I read here my tires still low.... Does the psi interfere with my gas milage -14mpg?
Our tires register
35.35.
35.34.
when fully warmed/hot, so it appears based on the info you were kind enough to provide we are between 3-5lbs low. So that means when the tires are fiully warmed you guys are seeing 37 front and 38 rear when set to the factory cold spec of 35/36?
I'm wondering if that's been contributing to our flat spot issues, as it very well could.
Thanks again.
Nitrogen definitely makes a difference. I have had five cars before this one that had tire pressure monitors and most of them gave me problems with warnings when using only air, especially in cold weather. Once changed to nitrogen, those problems went away. I have only had my ES 350 for a couple of weeks and was wanting to find out if it already has nitrogen in it, but judging from the previous comments, it apparently does not. That means I will get it the first time I take the car in for service.
