Oil Change write up?
6.8 qts of full synthetic oil. The weight is shown under hood. Go underneath take out the 2 bolts that hold the cover for filter. Then drain oil first. Then use a 3/8 socket and use a oil cap wrench to loosen the oil filter and take out the filter and install new one with the new o rings supplied and put it all back together and just add oil.
So on the oil filter cap, I'm suppose to remove the center bolt and put the plastic drain hose to drain the filter first followed by draining the pan. What is the part number for the oil filter and what is the size of the oil filter wrench, 64mm or 75mm.
Thanks.
Thanks.
azncapcom
06-15-20 06:51 AM
alpinefun
ES - 6th Gen (2013-2018)
10-09-19 10:58 PM
lilbluu
06-01-10 03:44 AM
