For the DIY'er : Jack Jaw
Old 03-11-13, 12:13 AM
sam430
sam430's Avatar
Default For the DIY'er : Jack Jaw
Figs just released this part and I'm sure there are some DIY'er who would love this. I don't know the dimension of this product but maybe FIGS can chime in when or if he see's this thread.
My GS won't go too low so I still can utilize this product.
Hopefully, he ends up doing custom parts for our GS sometimes in the future.
Old 03-11-13, 05:49 AM
Outrage
Outrage's Avatar
Does this fit on the pinch welds to spread the weight when jacking the vehicle? Do you have a link to a website for this product? I couldn't find anything using Google since the term "jack jaw" is common.
Old 03-11-13, 07:51 AM
passnu2
passnu2's Avatar
Figs is a vendor on club lexus
http://www.shopfigs.com/v1/
Old 03-11-13, 08:01 AM
IAMJAVEDG
IAMJAVEDG's Avatar
Great product!
Old 03-15-13, 08:53 PM
sam430
sam430's Avatar
I just received them today. Got a couple, just in case I lose one.
FIGS posted a vid.
https://vimeo.com/61929987
Old 03-16-13, 06:10 AM
BarrettF77
BarrettF77's Avatar
I guess I don't get the use of this product. If this was such an issue, why do dealers not have this or auto manufacturers redesign this?
Old 03-16-13, 08:31 AM
sam430
sam430's Avatar
This is for the garage monkeys like me. Shops/dealers have lifts.
Old 03-17-13, 10:49 PM
FIGS
The Maker
FIGS's Avatar
Hi guys, just to chime in.
The factory jack points are designed for the scissor jack that is provided in the trunk and not the major method for servicing the vehicle. On the lift the frame rails are used at least in the front and I am not sure even where the dealer positions the pads on the rear. In our shop we use these on the rear while we lift on the frame rails. We also use them at the track to change wheels. The length is equal to the reinforced area of the frame rail that is intended to bear weight. This version is high enough profile to keep the jack off of the factory side skirts as well while still allowing a lower clearance jack to get under them. Most shops I interviewed use pieces of wood. As far as I can tell no one has come up with a solution and I just got sick of bending the frame rails on the FIGS IS-F and came up with this device after about a year of testing. Planning on different versions for different applications and will also look into something for jack stands.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
dseag2
03-15-17 07:36 PM
MSMLexIS
08-06-06 12:22 AM
LexFather
03-02-05 05:04 PM
yaro1
02-28-05 09:15 PM
Quick Reply: For the DIY'er : Jack Jaw
