Rear License Plate Scratching Paint
Just thought I'd throw this out there ...
I finally got around to installing my rear license plate and discovered that the bottom edge of the plate/frame will eventually scratch or cut through the paint on the trunk lid over time. I had some of this around so I attached two strips side by side to the entire bottom edge of the rear plate and it appears to work well. I'll see how it holds up over time.
My plate was originally mounted poorly and had the same issue. I got the dealership to put some felt underneath the bottom edges when I heard the plate rattling against the trunk whenever I closed it. There are a couple of chips there from the first couple of weeks of ownership, but hopefully it helps.
So just be careful. Adhesive stuck on pain can easily be remove with a little soap and water
After a week of driving, dirt will get in between the strips and your paint. With small amount of dirt trapped between the strips and your paint you've essentially created a strip of sandpaper. Vibrations from trunk closure or driving over rough surfaces might create noticeable damage over the long run.
Thanks for bringing this up. Just checked mine and you can see very small marks (car is two months old). I used a small amount of gorilla tape (like duct tape but stronger, can be used outdoors) on the top where the screws go in and a bit of weatherstripping as you did on the bottom to act as a shock absorber.
My wife's RX has metal plates at the contact points up top. I think one of those details they overlooked on our cars. I'm a little disappointed to be putting weatherstripping on a $60K car!
So you guys know you can just bend the plate right? I ended up doing that right when I put the plate on the car as before the bend, the contact looked like it was going to be an issue. That being said I don't run a frame so I only have the plate to worry about.
Just thought I'd update this. I have a frame so bending the plate wasn't an option for me. Also the product I first tried in my original post didn't stick very well to the paint. I switched over to 11" of this single side adhesive foam tape and it seems to work perfectly.
