5 Ticks for Me
I did it myself, too. Took so long, the only way I got it done was having a couple of beers and a shot of tequila. I should have taken your advice above.
Not sure how to post a .PDF on here, but the adjustment procedure is:
1. ignition OFFi HOLD the wiper switch in the all the way up (OFF) position,
2. turn the Ignition ON, engine not running, and continue to HOLD the wiper switch in the OFF position for 5 seconds or more
3. Move the wiper switch down 1 position and for 5 seconds or more
4. Move the wiper switch up to the OFF position and Hold for 5 seconds or more
5. Move the wiper switch down 1 position and Hold for 5 seconds or more
6. Release the wiper switch. The right turn signal should flash 1 time
7. Place the intermittent wiper rotary switch in one of the following 4 positions
P1 - all the way down = 3 flashes
P2 - 1 up from the bottom = 5 flashes
P3 - 2 up from the bottom = 7'flashes
P4 - All the way up no flashes
8. Pull the turn signal switch down to the lane change position (not the turn
signal posilion) and release. The left turn signal should flash 2 - 4 times.
9. Turn the ignition OFF and then start the Car and test
Where does the Tequila come in to play?
Actually Bigblack06, the dealer did hand me a list of programmable options for me to tick off, but alas nothing about configuring the number of ticks on the turn signal. So best to just ask kindly at your next service stop, because that is one mind-boggling set of instructions. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Like you, I had mine done at 5,000 miles service too and you're correct in 5 being the perfect lane change blink. What I didn't know then, is that you can also change to volume of the clicker. Had I known that, I would have had mine turned down a couple notches. On the highway it fine but at a red light, the volume of the clicker is a little obnoxious. Next time, I'll have that done too.
Whole process took less than all of 2mins for me and it only worked when I actually started the car. I had tried 2x sitting in the garage with just the power on and got to the final steps for the turn signal stalk and no dice. Repeated steps with the car on and that did it!
NXOwner
NX - 1st Gen (2015-2021)
10-17-15 05:48 AM
