Wind noise w/window closed
My coworker's 2010 RX has the single pane glass side windows,my 2012 RX has the double pane side windows. My RX is markedly quieter than his. I have virtually no wind noise from the glass.
The 2010 RX's are getting retro fitted for the double paned windows if brought to the attention of the Dealers service department.
how is the wind noise w the new windows? is it noticeably less?
I have base AWD GS350 and it has double-paned glass (cold weather). I have not noticed wind noise from the driver side. After reading these "wind noise" posts, I was driving on the highway (50mph+) and with everything off can hear wind whistling but not constant noise...Is this normal? I did have my windshield replaced with OEM double-panned windshield tho.
yup, it's the weather seal around the door that's making noise, the dual pane is just so its not as noticeable from inside, but the noise is still there.
I wrote previously that I noticed this because after car wash the noise is reduced for about 10-15 minutes until the wind drys it out. This is because the water elvates friction between dorr stripping and body. I asked my dealer about it and they dont have any solution for this yet. I am waiting for next year modell and hoping they will revise the stripping.
I am reading heavly about three solutions right now:
1- applying a cemical, non corrosion to both paint and palstics, that elevates friction between stripping and body frame
2- applying som kind of extension mass on the stripping thus making its profile higher, tighter.
3- find a sceondery strip and apply it beside the actuall stripping,
I would appreciate any advice if you know of such products: -)
My dealer also suggested double pane window. Just came back from a road trip, went thru a very hard rain, you could see the tunnel effect between the side mirrors and the window with the rain, it blew the water down the entire glass along the seal, buffeting against the window.
The dealer is going to replace the glass with double pane and replace my tint.
http://www.ebay.com/itm/ws/eBayISAPI...ectorid=229466
I have bought five kinds of sillicon glue to extend the profile hight. Two of them didnt adhere very well. will try the rest soon. Today I made the 15tkm check up and got a loaner GS 250, it had the same issue, and I do have the winter windows set up. I am reading about noisemeters, and will order one soon, (cost about 3500-4000$). I am thinking it will serve me well in future purchases,
