Blue light
Old 05-01-13, 09:09 AM
cwang215
cwang215's Avatar
Default Blue light
I barely noticed that the blue light above the speedometer dims as you slow and brightens as you accelerate after four months of owning this awesome car. Just thought that this was a pretty cool feature.
Old 05-01-13, 09:36 AM
terrycs
terrycs's Avatar
I guess you haven't seen it turn red yet?
Old 05-01-13, 09:37 AM
djpeakSD
djpeakSD's Avatar
I have mine set to stay blue!!!!
Old 05-01-13, 10:40 AM
maxwebr
maxwebr's Avatar
put in sport mode and it goes RED
Old 05-01-13, 10:56 AM
triquynh
triquynh's Avatar
Mine is blue even if I put it in Sport or Sport+. I thought everything like the speed/tach turns red..everything is all blue on mine no matter what. setting. Do you guys know how to adjust it?
Old 05-01-13, 12:39 PM
cwang215
cwang215's Avatar
Interesting. I'll try it!
Old 05-01-13, 01:55 PM
BigAnthony
BigAnthony's Avatar
Actually it gets more blue as mpg's go up. So if you step on the gas it dims until you let off and coast then it gets bright but as you step on the gas it dims as mpg's go down as you step on the gas. The more you depress the gas the dimmer it gets but as you coast it gets brighter until a full stop then it dims again.
Old 05-01-13, 03:14 PM
DrKeith
DrKeith's Avatar
You can adjust whether the blue stays bright, dims based on mpgs and also if the sport modes switch the light to red using the DISP settings on the steering wheel (sport and ECO) light settings.
Old 05-01-13, 11:55 PM
dchar
dchar's Avatar
The light is suppose to turn red when you turn it to Sport and Sport +. Might want to have your dealer check that...
Old 05-02-13, 05:46 AM
Outrage
Outrage's Avatar
If the light is set to a constant blue illumination, it will never switch to red in Sport or Sport+ modes.
Old 05-02-13, 10:11 AM
zicogold
zicogold's Avatar
Please elaborate Outrage. I have taken my car to the dealer and complained that the is blue all the time and does not change intensity in Eco mode, the dealer says that is the way it is suppose to operate. So what keeps the lamp set to constant blue illumination?
Old 05-02-13, 10:36 AM
DrKeith
DrKeith's Avatar
If the eco lamp is set to on then it will stay constant. Try setting eco lamp to self lighting and sport lamp to on for the red in the sport modes.
Page 87
drivers.lexus.com/t3Portal/document/om/OM30C34U/pdf/sec_02.pdf
Old 05-02-13, 11:03 AM
Outrage
Outrage's Avatar
Configure this within the multi-information display by cycling through the displays using the "DISP" button. It is within the settings menu. Adjust the "ECO lamp" setting from "ON (Always)" to "ON (Self-lighting)".
Old 05-02-13, 01:12 PM
zicogold
zicogold's Avatar
DrKeith I had taken your advice in a previous thread devoted to my plight with the light, but I did not succeed. I think it is because I did not follow the directions fully, as Outrage points out the setting must be on "self lighting". Let me try this and report back.
Old 05-02-13, 08:03 PM
dseag2
dseag2's Avatar
I haven't noticed the brightening vs. dimming, but then the last thing I look at when I step on the gas is the blue light. I'm usually looking at the red light hanging above me or the car I'm going to pass.
Quick Reply: Blue light
