F-Sport front emblem help!?!
Just received the black pearl front emblem from sewell the other day. In the process of removing the old one, I see that there is some type of fasteners on the back that is not that easy to remove. I don't know if I should just try some force since the bottom half just has a clip, but I feel like I can possibly break it.
I don't really want to remove the front grill, and it's easy enough to reach by removing the front half of the engine cover. I know people have already done this swap out already and I'm looking for tips on trying to remove it. Especially since it appears I need to reuse them.
I was trying to do that and it seemed like I was going to crack the grill. I thought about using a small screwdriver to lift some of those pins. Appreciate the feedback.
Attachment 291118
Attachment 291118
I used an L-shape pick and worked my way around the outside. Just take your time
lexusnyny - when I changed out my emblem you have to take some pliers and pull off the tabs in the back...then make sure you have new ones from sewell to replace them because once you take them off you can't put them back on.
My post is here:
https://www.clublexus.com/forums/gs-...my-fsport.html
My post is here:
