Running lower PSI for a softer ride?
Old 09-24-13, 11:45 AM
Received 2,751 Likes on 1,968 Posts
Dealers ALWAYS over-inflate the tires. No need to take it back, just deflate them.
Old 09-24-13, 01:04 PM
Lexzam
Lexzam's Avatar
As said already above:
lower tire pressure equals worse fuel economy and used to mean early wearing out of the edges. However, the latter is not really so much an issue any more with new tires.
higher tire pressure is better for fuel economy, heavy load and fast driving. Conversely high pressure used to wear out the middle early on, but not any more an issue with today's tires. One can safely exceed the recommended tire pressure quite a bit. The ride should also be harsher, but the difference is much less than low profile tires compared with standard profile tires
Old 09-24-13, 01:23 PM
Theres nothing about modern tires that makes it so under-inflation won't cause excess wear...ins a matter of physics.
Old 09-24-13, 01:33 PM
praetor
praetor's Avatar
I concur. Not to mention that under inflating your tires can cause excessive heat buildup. Heat alone will shorten the life of your tires. Run flats especially have the heat problem and that's why you can only drive it a short distance if you lose tire pressure.
nkseto
07-26-16 12:46 AM
leg3ndary
07-25-16 09:51 AM
chromedome
ES - 6th Gen (2013-2018)
12-01-15 07:53 PM
AL13NV8D3R
03-14-14 12:42 AM
TOPLEXS
01-02-02 07:11 AM
Quick Reply: Running lower PSI for a softer ride?
