Regarding usb
So I took out my USB last night and completely reformatted and wiped it...and threw new music back on yet, folders that I did not put in there are still showing up on my nav? I did throw those files in the first time loading music up and played it in the nav but completely deleted them popped the USB back in and they still showed up?
I figured I would wipe the USB clean and throw some music back on there yet it still has these "techno" folders and songs wtf!!??
They showed up - but are you able to actually play them? I suspect the nav might be caching the titles/folder-names.
If the files are truly not on the USB, you won't be able to play them. Ideally, the Nav should have detected that the folder layout/files had changed, and rescanned the USB drive. Not sure why it didn't though. Your dealership should be able to help.
Yeah the navigation displays them and still plays them!!!! My thumb stick is formatted to fat-32...reformatted and everything!! Maybe I should try resetting user settings on my nav?
If the nav is still able to play them from the USB drive, then the files are still on your USB drive. It has nothing to do with user settings on Nav ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
The nav unit on the GS doesn't have a hard drive to rip/copy music to, so it can't store a copy of the songs.
Plug the USB drive into your computer, and re-check whether those files are there in some folder/sub-folder etc.
JohnnyCake
11-08-09 07:07 AM
