Maintenance Required warning?
So I keep getting this indicator on my cluster and cannot seem to locate where it's coming from. When I look in my navi under Maintenance, all I see is oil change/filter activated and still 5000 remaining until the indication.
Any ideas where else this may be coming from?
Is it the check engine light. I know these auto manufacturers get all kinds of creative to make it so you take the car in instead of knowing what a warning light is for. I mean we have 2 LCD screens, one of which is almost 13" and they can't simply make the car pop up a alert with x and y have detected a malfunction. Imagine how the service department would feel if they actually knew ahead of time what the car was needing. BMW did this on the 7 series a decad ago with you just giving them the fob and being able to know what was wrong. Why can't a car 10 years later self diagnose AND tell the driver what that diagnosis is.
Seems kind of silly. Post a pic if you can as I've yet to see this indicator.
Is it the check engine light. I know these auto manufacturers get all kinds of creative to make it so you take the car in instead of knowing what a warning light is for. I mean we have 2 LCD screens, one of which is almost 13" and they can't simply make the car pop up a alert with x and y have detected a malfunction. Imagine how the service department would feel if they actually knew ahead of time what the car was needing. BMW did this on the 7 series a decad ago with you just giving them the fob and being able to know what was wrong. Why can't a car 10 years later self diagnose AND tell the driver what that diagnosis is. Seems kind of silly. Post a pic if you can as I've yet to see this indicator.
No this is just the factory 5k service light. To turn it off just set the odometer to trip a then turn the car off. Hold the trip button down while Turing the on to acc not starting it and you will see the maintenance required light reset.
curio
09-22-17 11:27 AM
