Bluetooth streaming, all of a sudden no audio...
Kind of a weird issue. All of a sudden when streaming Audio from my iPhone (iPhone 5 with iOS 6), I have no audio. Song info transmits fine, can browse and select, timer runs, but no sound. Tried pausing, playing, selecting the audio output source on the iPhone, nothing. When you switch between the iPhone and the car for the output source it plays on the iPhone's speakers but when you switch back to the car nothing.
I've rebooted the iPhone, cycled Bluetooth. Paired and unpaired. I know its not the phone because it still plays in the Jeep. Plugging the iPhone in works fine.
Any thoughts?
Any thoughts?
Are you getting an audio from the radio/ XM or even the Navigation. On my mom's 07 LS she was driving listening to the radio and then it "popped" and no audio was coming out no phone, radio/XM not even the beeps from the nav UI. It turned out the amp died in the car and thank got for the extended warranty. They had to order a new ML amp.
the same thing happened to me when i had the GS... although i thought for some reason the BT lost connection with the car because the music played through the phone and not the car speakers. i believe i turned the car off and then back on after a minute or so and it worked fine. that's the only time that had ever happened. i thought it was just me, but i didn't post because it only happened that one time.
Its been restarted several times now and no dice. Been going on since yesterday...
wow... uuummm, i'm stumped other than suggesting a trip to the dealer. although i know there is a solution to this dilemma. it's happening to other owners so i think a dealer visit is more than likely going to happen.
I'll check the volume output on the phone, although like I said my phone streams fine in the Jeep. Does it hold different volume levels for different output sources (Lexus BT system and Jeep BT system are separate sources)...other than that I'm stumped!
did you try calling to see if that works?
i'm sure you already know bluetooth is just series of profiles... and a phone can be turned on or off individually.
you might just have A2dp disabled in your BT settings.
you can also delete the phone pairing from the car and reconnect again.
Phone calling works fine.
I hate to un-pair the phone and re-pair it, because every time you do that you have to go in and reprogram all the speed dials...PITA...
I just got home, my wife is still at work when she gets home with the GS tonight I'll play around with it and report back.
