USB goes to audio off
Old 12-06-13, 02:23 PM
JT51
JT51's Avatar
Default USB goes to audio off
While playing music from a usb stick, it will go silent, not show on media screen as being an option and say audio off. I have tried two different sticks with the same result. If I unplug the usb and plug it back it will start playing where it left off, then do it again, stop playing and show audio off. There is power to the usb, because it is still lit when all this happens.
Old 12-06-13, 04:39 PM
95bat
95bat's Avatar
Received 1,328 Likes on 680 Posts
Does it do it on the same song or same file type?
Old 12-06-13, 04:51 PM
JT51
JT51's Avatar
no not the same song, also random time from when it goes off, when I put in a different usb it played for about 25 minutes and I thought it was the original usb, then it went to audio off, and wouldn't play one song after that, before going to audio off
Old 12-06-13, 10:50 PM
richard203
richard203's Avatar
mines do that for ipod.
Old 12-08-13, 03:26 PM
95bat
95bat's Avatar
Hmm, I'm stumped. You might have to take that to the dealership. If 2 different USB drives have the same problem, it's probably something in the car.
Old 12-08-13, 10:21 PM
richard203
richard203's Avatar
but its sametimes mybe next time ima record it and show it to my dealership.
Old 12-10-13, 07:13 AM
jucytec
jucytec's Avatar
did some one spill something into the USB hole? something with sugar in it? sugar water never dries in circuitry... and if something warms it up, it's viscosity goes down and... becomes conductive enough to short out the circuitry... the 2 pins in the middle carry data, and shorting them out basically puts it into charge only mode...
this is a huge accusation on my part, but... sounds strikingly similar... does it happen more once the USB Stick / Car interior is warmer?
Old 12-10-13, 10:39 AM
yok3dIS
yok3dIS's Avatar
Same here, I'd be listening to a track and it will just randomly turn off - Audio Off
Old 12-10-13, 11:44 AM
JT51
JT51's Avatar
I have always used a splitter, one slot for charging phone, and no problems, when this started I had plugged the two different USBs directly in and got the "audio off", today I went back to the splitter and had no problems????? no audio off, just kept playing.
Old 12-11-13, 10:54 AM
rx10owner
rx10owner's Avatar
The cure, at least for an iPod classic, is to turn off "display cover art" in the setup screen. Had my GS for about a month before I figured it out. May work for the USB stick as well.
Old 12-17-13, 12:00 AM
richard203
richard203's Avatar
seems like the problem is when u move the cable or usb it will cause the problem. Last time I just searching for somerhing and moved the ipod or the cable the audio turned off.
calmondo
ES - 6th Gen (2013-2018)
20
03-16-20 12:20 PM
dingles
Hybrid Technology
10-24-18 12:48 PM
doodlebug
03-09-16 06:01 PM
DrKeith
06-19-12 08:36 AM
gfitz2010
RX - 3rd Gen (2010-2015)
01-08-11 07:10 AM
Quick Reply: USB goes to audio off
