Easy exit
Recently my easy exit isn't working correctly. My steering wheel moves up but my seat doesn't move back when I turn the car off. Has anyone had issues with this? Thanks!
On my GS I think if you adjust the seat via the switch it'll do this. Try starting the car, pressing the memory seat button so it moves into your set position then shutting the car off. That's assuming you have memory seats though.
I think I figured it out. I believe the seat has to be a certain length forward for it to engage the seat moving back. I'm almost 6'4 so my seat was pretty far back but not all the way.
I have the opposite problem. I don't want my seat to slide back for easy exit, so in my settings I have neither partial nor full. However, there have been a few times when it has slid back and then I've had to hit my preset button to put everything back into place. I use the same key every time, so I'm assuming this is just a glitch.
