Everyone check ur spare tire area for water
Is there any water damage to the particle board that is used to cover the spare tire area? That will be your first indication on where the water is coming from. If not, then it is coming from the bottom, however, if there is a hole underneath the tire, the water would drain on its own...
Weird.
Weird.
Isn't there a drain hole under the spare tire? Maybe it's missing and letting water in?
Ed
Ed
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Does this model have holes by the sunroof that carry built up water for disposal? Does the water go to the back or front of the car?
Just found my trunk space filled with water!I removed the drain plugs(and everything else in there).Floormat was soaked too.The vertical liner was dry all around.I hosed down the rear window but found no leaking from there,trunk rubber is fine.Will take it to the local "Glassmaster" to have it checked.Will return.
Lmk what they find
