Need Help tire size for aftermarket Wheels!!
Old 01-06-14, 12:49 PM
ntubeusa
ntubeusa's Avatar
Default Need Help tire size for aftermarket Wheels!!
Help, will the 255/30/20 too small for rear ? The aftermarket wheels I am going to put on are 20x10+40 offset. Need Help
Old 01-06-14, 05:01 PM
mshmsh
mshmsh's Avatar
wont be too small but it will be narrow and you will need to drop the car more so it covers the gap. I would go with 275/30/20.. do not forget that your stock wheels are: 265/35/19 on 19x9
so if you go 1 inch more 20x10 with 40+ offset I would go no less than 275/30/20 ... Do not miss it up
Old 01-06-14, 08:05 PM
ntubeusa
ntubeusa's Avatar
Thanks for the info, I want to go with 275/30/20 too, however base on the Rays web site it suggests the tires sizes are 255/30/20 for the rear. I am worry it will rub if I go bigger than 255
This is the wheels I am going to get. and the info from Rays Japan
http://www.rayswheels.co.jp/2009/pro...&code=GL_57FXX
Old 01-06-14, 08:06 PM
ntubeusa
ntubeusa's Avatar
oops, it should be 45offset not 40
Old 01-06-14, 08:36 PM
mshmsh
mshmsh's Avatar
Rubbing happens in front if you go 20x9. but 20x10 in rear is fine. most of the members here are going for 20x10.5 with 285/30/20 so they have rubbing issue. I wouldn't listen to a what websites have to say. I go and see what my eyes tell me. Actually you are doing the perfect size 20x10, I would also go 20x8.5 front and tires sizes 275/30/20 and 245/35/20, respectively. If I were you I would do 235/35/20 front ( hard to find those tires though) and 275/30/20 with Tanabe springs. The reason I say this because I found out that Tanabe's springs drop the front more so you could play a bit with the size of the tire and put 235/35/20 instead of 245/35/20.
and everything I just said is my opinion and based on many F sports I have seen with aftermarket rims.
you do your own thing
Old 01-06-14, 09:41 PM
ntubeusa
ntubeusa's Avatar
Thank you so much mshmsh, I will post picture afterward.
Old 01-06-14, 11:23 PM
mshmsh
mshmsh's Avatar
Of course we wanna see that wheels look nice and will be nicer on GS
Old 01-11-14, 12:23 AM
ntubeusa
ntubeusa's Avatar
mshmsh thank you so much for your helped, I am using 275/30/20 and it has no problem at all. Iike you said 275 it's perfect size and it lower with Tanabe springs hopefully it will lower a little bit more later on, it's a bit higher than my M now
Thank you so much Mshmsh
Attached Thumbnails Need Help tire size for aftermarket Wheels!!-img-20140110-wa0011.jpg   Need Help tire size for aftermarket Wheels!!-img-20140110-wa0010.jpg
Old 01-11-14, 07:08 PM
LGSFS2012
LGSFS2012's Avatar
looks good. 275 was the way to go.
Old 01-12-14, 12:47 AM
mshmsh
mshmsh's Avatar
WOW look how nice the car is sitting ...
drive about 600 miles and look how the front will drop. it'll be different and better
great setup and nice color combo .. congrats and give it some HD pictures later on
AlexW
03-28-17 09:41 PM
ISMY350
06-21-12 11:56 AM
jc11
11-04-10 12:52 PM
edub669
SC- 1st Gen (1992-2000)
06-17-10 07:01 PM
tommyGS3
Wheels, Tires & Brakes Forum
12-15-05 08:02 PM
Quick Reply: Need Help tire size for aftermarket Wheels!!
