Installed an axle back exhaust, but not too happy
Old 03-02-14 | 08:40 AM
SNiiP3R's Avatar
SNiiP3R
Default Installed an axle back exhaust, but not too happy
I get this strange hissing / high pitch noise inside the cabin, around the dash area. Only when I accelerate and only around 2 - 3rpm. If I'm parked and rev the engine I don't hear it at all.
I went to check for exhaust leaks today. They lift the car up, plugged both exhausts then checked for leaks, but did not find anything
Not sure what else to check at this point.
Old 03-02-14 | 08:42 AM
13FSPORT's Avatar
13FSPORT
Which one did you get?
Old 03-02-14 | 08:44 AM
SNiiP3R's Avatar
SNiiP3R
I went with JoeZ, I could not wait for Tanabe any longer
Old 03-02-14 | 10:14 AM
jjscsix's Avatar
jjscsix
Isn't that the range that the car pipes in synthetic exhaust noise (or is it "intake" roar they pipe in?).
Old 03-03-14 | 06:30 AM
ronfsp's Avatar
ronfsp
Fix back the original to see if the sound persists. If it does then it's not the exhaust...
Old 03-03-14 | 04:10 PM
SNiiP3R's Avatar
SNiiP3R
I went to 2 shops. The first shop did not find any leaks. The second one said that the screws are too tight and that maybe causing vibrations inside the cabin. They also said that I should try the original bolts with springs. So, we did that. However, that did not help at all, I get the same hissing / high pitch sound inside the cabin when I accelerate.
Old 03-03-14 | 05:06 PM
Joeb427's Avatar
Joeb427
Did you talk to or PM Joe Z?
Old 03-03-14 | 05:08 PM
SNiiP3R's Avatar
SNiiP3R
Originally Posted by Joeb427
Did you talk or PM Joe Z?
His PM box is full not accepting any more msgs
Old 03-03-14 | 05:11 PM
Joeb427's Avatar
Joeb427
Not good.
I know that issue would be driving me nuts.
Old 03-03-14 | 09:10 PM
Schmexus's Avatar
Schmexus
I had a pinhole in my midpipe that made a similar noise only on hard acceleration. It was very hard to find on one of the weld joints. It was a very tiny hole, but made a very annoying sound that you could hear in the cabin when you stepped on it.
Old 03-03-14 | 09:16 PM
elusive's Avatar
elusive
Try contacting him on Instagram @JoeZPerformance
Like someone else said, install the oem mufflers and see if the noise is there.
Old 03-10-14 | 06:23 PM
razo168's Avatar
razo168
I am trying to get rid of my JoeZ full cat back - selling the car. I posted it up on ebay today but I don't think I can post the link here. - After putting it back to stock - I had an exhuast leak, took it to dealer and took care of it. A lot of times, it's the gaskets that are used. Get some NEW oem ones.
Old 03-19-14 | 11:13 AM
Joe Z's Avatar
Joe Z
Lightbulb
Following up for "SNiiP3R"
We helped him through PM as well..
Joe,
No leaks, No defects. Your exhaust is fine. It was my windshield that was not installed properly, the noise I was hearing was coming from a break booster. So all is good!
Thanks,
SNiiP3R
Regards,
~ Joe Z
Old 03-19-14 | 11:30 AM
SNiiP3R's Avatar
SNiiP3R
Thanks Joe! Sorry, forgot to update the thread. Exhaust is great and so is the service.
Old 03-19-14 | 02:08 PM
SmokeTL's Avatar
SmokeTL
So how does the exhaust sound?
