Does S+ mode equal quicker wear?
I mean, aggressive driving will cause quicker wear...
But...you bought the car to drive and enjoy...so drive it and enjoy it. Struts...I mean maybe at 150k+? Maybe using Sport + wears them out at 140k miles. Are you even going to have the car at that age?
I'm with you there. Even the freeways have random potholes that you never see coming. I'm a Sport mode guy, I don't trust most roads enough (except GB tollway, and even then, only in sections) to use full Sport+.
Man, you make Dallas sound like Iraq or something. Dallas has good roads. Try NJ or NY if you want to see some bad roads.
Engineering answer: Yes, but most probably hardly a difference. As I understand it, the Lexus system only adjusts the shock's damping (not spring rates), and it does so by varying the size of the orifice between the two chambers inside each shock. This is very similar to how most physically adjustable shock absorbers work (such as Tein's system, more info at http://www.tein.com/classroom/lesson_1.html). Magnetorheological shocks (like the kind used on the Cadillac CTS-V) operate by differing the kinematic viscosity of the fluid versus physically changing orifice size, but the end result is the same: increased pressure on the seals).
The periods of higher pressure inside the chambers (due to the smaller opening between the chambers when in Sport+) could potentially contribute to a greater wear of the seals. However, the overall difference in life of the shock is probably so small that you wouldn't care. I mean, if you want the sportier feel of 'tighter' shocks, then that's what you want, so drive in Sport+ mode and be happy! But if you are truly trying to maximize the life of your shock absorbers (and OMG why on earth would you care, but maybe) then keep it out of Sport+ mode.
I kept my last '00 GS till 200K. I tend to keep my cars very long.
Short answer: No. Engineering answer: Yes, but most probably hardly a difference. As I understand it, the Lexus system only adjusts the shock's damping (not spring rates), and it does so by varying the size of the orifice between the two chambers inside each shock. This is very similar to how most physically adjustable shock absorbers work (such as Tein's system, more info at http://www.tein.com/classroom/lesson_1.html). Magnetorheological shocks (like the kind used on the Cadillac CTS-V) operate by differing the kinematic viscosity of the fluid versus physically changing orifice size, but the end result is the same: increased pressure on the seals). The periods of higher pressure inside the chambers (due to the smaller opening between the chambers when in Sport+) could potentially contribute to a greater wear of the seals. However, the overall difference in life of the shock is probably so small that you wouldn't care. I mean, if you want the sportier feel of 'tighter' shocks, then that's what you want, so drive in Sport+ mode and be happy! But if you are truly trying to maximize the life of your shock absorbers (and OMG why on earth would you care, but maybe) then keep it out of Sport+ mode.
https://www.clublexus.com/forums/is-...ing-sound.html
I also moved to Dallas from Miami, so maybe that's why the roads seem rough.
I second that, I had to take one of these through Jersey City and it felt like I was dodging land mines, I'd really love to see some state projects this summer to fix the roads that were already bad and made worse after this last winter.
No, I'm not making Dallas sound like Iraq. I don't know what part you've visited, but I live in East Dallas and our roads are constantly being repaired. If you don't believe me, look at the fifth post in this thread.
Yeah East Dallas makes a little more sense but still they aren't that bad. I live in North Dallas and driving there is like driving on a cloud compared to NY/NJ. I am in Queens on business right now and I swear if I had to live here I wouldn't even buy a nice car let alone put nice wheels and low-profile tires on it.
