Headlight removal
Old 03-13-14, 02:29 PM
Polo708
Polo708's Avatar
Default Headlight removal
Can the GS350 headlamps be removed without removing the front bumper? I have an F-Sport, but dont think it differs any from the base GS in this area.
Old 03-13-14, 02:42 PM
onexcite
onexcite's Avatar
The bumper need to be removed (at least partially). There are bolts lying underneath the bumper.
Old 03-13-14, 03:07 PM
SNiiP3R
SNiiP3R's Avatar
Yup, no other way to get to the headlight. Taking the bumper off is not difficult, should only take you about 15 - 20 min. But like onexcite said, you can remove it partially if you only working either on right or left headlight. You don't have to worry about the other side.
Old 03-13-14, 03:09 PM
Polo708
Polo708's Avatar
Thanks. I was worried about those sensors and messing with the bumper. Do you know how many bolts there are? Are they accesses from the front or from the underside?
Old 03-13-14, 03:25 PM
e39ng
e39ng's Avatar
Here's the instruction to remove the front bumper:
Old 03-14-14, 08:49 AM
Polo708
Polo708's Avatar
^^ awesome, thanks!
Old 04-22-14, 08:45 PM
Polo708
Polo708's Avatar
I'm attempting this bumper removal tomorrow or the next day. On step (e) it says to "detach the 10 claws". Has anyone attempted this? Is the bumper basically just going to disconnect by pulling straight out?
Old 04-22-14, 08:50 PM
mrpartsman
mrpartsman's Avatar
yep once u take all the clips out u pull on it and it comes right out.
Old 04-23-14, 10:37 AM
Polo708
Polo708's Avatar
Got the bumper off, there was an extra bolt inside the wheelwell that holds the bumper to the fender. Its easy to find.
I found where the water was geting into my headlight. The top plastic mount was broken and was slightly lifted. It took enough of the plastic below it to make a dime sized hole on the top of the headlamp housing which was allowing water and condensation in.
My question now is what type of epoxy or glue should I use to reseal this? Which type is best with plastic and being resistant to water?
Old 04-23-14, 12:03 PM
G-SharK
G-SharK's Avatar
You can try silicone or epoxy
Old 04-23-14, 12:10 PM
yardie876
yardie876's Avatar
Originally Posted by Polo708
Got the bumper off, there was an extra bolt inside the wheelwell that holds the bumper to the fender. Its easy to find. I found where the water was geting into my headlight. The top plastic mount was broken and was slightly lifted. It took enough of the plastic below it to make a dime sized hole on the top of the headlamp housing which was allowing water and condensation in.
Hmm that's odd. I wonder why it was broken... A good dab of epoxy will seal that right up though.
Old 04-23-14, 02:50 PM
SNiiP3R
SNiiP3R's Avatar
I think I told you in another thread to check those first glad you found the problem.
Buy this, http://www.homedepot.com/p/J-B-Weld-...65-s/100189012
Do the repair at home or in a garage. You need the glue to cure, the one I posted usually takes 8 - 12 hours. For best results, do it at around 5 - 6pm and leave it overnight to cure. In the morning it will be solid like rock.
Old 04-23-14, 09:44 PM
Polo708
Polo708's Avatar
Awesome thanks. It's the tab on the outside corner so the headlamp assembly still needed to come out to get to it.
eddie25
CT 200h Model (2011-2017)
05-30-19 06:49 PM
JZFsport
05-30-18 06:33 AM
Dble Agent
IS F (2008-2014)
05-29-13 08:39 PM
GSXOTIC
01-19-05 10:03 PM
Quick Reply: Headlight removal
