What's the most annoying setting on your GS?
When you start the car and put it in R, backcam mode. OSD from both Bluetooth and temp on upper screen field renders the visiblity to ziltch because of the fish-eye uppercut in viewed field. Its a hazard because you are om reverse mode, back lights are lit and other drivers might be waiting for you to move your bud. You lose a god 10 sec which puts strain of many of our ADHD-drivers.
I wish there was more control on the seat easy exit option. I really like to have it on except when I have a passenger behind me. I always forget and end up cramping the rear seat passenger to when getting out. I can disable it through options but it is a cumbersome process. I wish there was an easy on-off for it.
Pete
Pete
I have used my 2:d settings button for this. The 3:d is a backup of my 1:st position. Its a bloody hard time to adjust lux seats,
Former Sponsor
I agree, solved it by adjusting the steering wheel to 0 position both short and high. This is by far the fastest 2 momentum stage to exit. If you engage your seat, it will take another 5 second. Car cycles through chair and steering in order not simultaneously; thus a delay.
Btw, the latest beta version of Carista is out, and it includes the option to disable the auto seat movement (or set it to half-distance). The beta is available here: http://www.caristaapp.com/beta/ . There are also settings to enable/disable the auto-movement of individual parts of the seat: side support, lumbar support, pelvis support, and ottoman. But those are available only on some models (maybe with lux seats?). Actually, if you have lux seats, I'd be very interested in seeing what Carista shows as available options on your car. Do you happen to have an ELM327 Bluetooth OBD adapter? It's free to hook up Carista and see what settings are available on your particular car.
Setting the performance value to "Sport S+" when the car starts, instead of turning the dial twice.
I'm not even sure this can be changed.
1. I dislike the voice commands
a. Play music -- Play playlist R and B
b. Is that correct?
c. yes
Wish I could just say "play playlist R and B" and it would start playing. (also I think I lost my shuffle command)
2. find nearby home depot
a, instead of listing out 5 home depots and giving an arrow and mileage counter, it should show all 5 home depots on a map in relation to where the vehicle is currently. Its cumbersome to go into each one and decide if that's the one I want to go to.
b. Is that correct?
c. yes
As far as I know, it can't, and this is tied in with emissions and fuel efficiency testing. I've seen various explanations that boil down to this: if a more aggressive ECU mode can be set as a default, then testing will be done in that mode (possibly averaged with the least aggressive default-settable ECU mode). So there is incentive for manufacturers to make it so the more aggressive modes have to be re-selected every time, so that they don't have a negative effect on the test results.
Former Sponsor
Most annoying thing is not being able to us the Nav when driving!!
I get that I should not do it myself and the dangers of doing so, but if I have a passenger that can play around and find a restaurant and what not, then why not let them.
There are toggles for those indicators in the set up menus. Can't remember offhand how they are labeled but take a look. I f you can't find them, I'll try to track them down for you.
Jessek1486
10-27-18 08:00 PM
