Rim Fitment Questions
Hello,
Is anyone running 20x9 with a 25 offset front and a 20x10.5 with a 30 offset rear?
If so is there any rubbing issues? Do you have pics?
If this has already been discussed can someone point me to the correct thread?
Thanks so much.
Thanks so much.
I like the 'flush' look, and from what i've seen here, 9 +34 and 10.5 +45 is about flush. Adding a 9mm poke in front and 15mm poke in the rear seems doable but probably w/rolled fenders and a good tire stretch. How you plan on lowering (spring/coilover/air) will make or break that fitment, imo.
