how to properly jack up a lowered 4gs fsport
Old 05-28-14, 12:13 AM
fsportjay
fsportjay's Avatar
Default how to properly jack up a lowered 4gs fsport
based on what I see in the owners manual, if I want to lift the car with a floor jack, I need to use the jacking point under the front cross member or rear axel. my floor jack will slide under the car, but being lowered on tanabe springs, I can't reach the jack points and have room to pump up the jack. what method are you guys using?
Old 05-28-14, 06:48 AM
G-SharK
G-SharK's Avatar
I am also lowered on Tanabe. You will need two jacks, jack one side until you can get the other jack to the front cross member. Once you make contact with the front cross member, lower the side jack and use just the front jack. When you need to lower, just put the side jack back on... you know what to do.
Old 05-28-14, 08:02 AM
mso4
mso4's Avatar
I'm on Tanabe and I use a low profile jack. Your average jack won't do it.
The alternative is to go to Home Depot and buy some 2x10 woods. You'll need at least 2 pieces about 3' long. Place in front of your front wheels. Then drive your car on top of it. You might need to double up depending on your jack. That should give you enough room to put jack under jack points.
They also sell ramps but if cheap HD wood works why not.
Old 05-28-14, 08:34 AM
Dukeaudio
Dukeaudio's Avatar
Agree w/lumber (i use 2x10's).
Old 05-28-14, 08:56 AM
mrpartsman
mrpartsman's Avatar
if ur in CA. go to harbor fright and get yourself a low profile jack for $60 and that does the job.
Old 05-28-14, 09:09 AM
mso4
mso4's Avatar
This is the jack I use:
http://www.otctools.com/products/2-ton-service-jack-ultra-low-profile
I've had it for about 7-8 years and I love it. Did have to bring it in for service about 5 years ago under warranty for a seal leak. It's low enough to reach under the 4GS/ Tanabe jack point in the front. I also used it when I had the Vettes.
Old 05-29-14, 04:54 PM
fsportjay
fsportjay's Avatar
thanks for the feedback everyone.
Old 05-29-14, 05:16 PM
JEFFOS69
JEFFOS69's Avatar
Another vote for driving up some wood first. I've had super low cars in the past and it works every time
JCarvallo
07-22-19 08:33 PM
mdgrwl
Performance
53
12-08-11 10:54 AM
mikes rx
Performance
12-08-11 10:54 AM
ldc
Suspension and Brakes
12
05-22-10 05:50 AM
elmerrox
03-12-08 01:22 PM
Quick Reply: how to properly jack up a lowered 4gs fsport
