Opinion on Brakes
Old 06-08-14, 09:33 PM
mdhaliwal
mdhaliwal's Avatar
Default Opinion on Brakes
Hi All,
I am considering upgrading my brakes because I am thinking about getting some bigger wheels, and as it is right now, I feel like the brakes are just a little "soft". I have a 2013 AWD F-Sport, therefore I did not get the 4 piston calipers Also, I am coming from a 2008 Audi A4 which is significantly lighter than the GS, and well felt like it had better braking ability. Any how I wanted to get your guys opinion on a few things:
  1. Could my issue just be brake pads? I bought the car used with about 18k miles on it, so I am guessing it still has the same pads that it came with. Will a good set of ceramic pads help?
  2. Sewell has F-Sport calipers for the RWD listed for around $600-700, is the upgrade to these calipers worth it? Has anyone done this? Is it even doable?
  3. I was looking at StopTech BBK's but didn't see one specifically for the GS, are there any out there? I know these will definitely make a difference, but at almost $4k they are a bit pricey, are there any other BBK solutions out there on the market, besides Brembo and StopTech, that are a good bang for the buck?
Thank you!
Old 06-09-14, 08:27 PM
gotink
gotink's Avatar
From what I understand the fsport 4pot caliper is made by stop tech...these do the job great for a daily driver, I'll just be doing stainless lines and call them good to go...if your tracking it often then go for the bbk..
Old 06-09-14, 09:42 PM
mdhaliwal
mdhaliwal's Avatar
Nice thanks man! Maybe I should work with a fabricator and get mounting plates for throwing the stock 2 piston calipers on the rears, and upgrading to the 4 piston up front - call it a BBK
Old 06-09-14, 11:36 PM
TruPlaya26
TruPlaya26's Avatar
Where are you getting the SS lines from?
Old 06-09-14, 11:54 PM
gotink
gotink's Avatar
Custom made....my tire shop has a guy...
Old 06-09-14, 11:55 PM
gotink
gotink's Avatar
I belive it also has bigger rotors all around also. I know the fronts on mine are a 2 piece rotor so don't know what cost you'd be looking at check out Sewell for pricing...
Old 06-10-14, 04:19 AM
DaSyce
DaSyce's Avatar
Lexus website is actually wrong, all GS350’s come with 4 piston front calipers and single piston rear calipers. The design is a carryover from the previous generation.
RWD F-Sport caliper design in slightly different as the calipers are now extended to accommodate a larger rotor.
I see why these is so much misinformation as Lexus marketing didn't get the memo and have this wrong on their website.
You should try a more aggressive replacement pad, and brake fluid changed to eliminate moisture in the lines.
Old 06-10-14, 08:43 AM
mdhaliwal
mdhaliwal's Avatar
Wow thanks, good to know!
Old 06-10-14, 12:00 PM
terrycs
terrycs's Avatar
StopTech's aftermarket setup is 6 front / 4 rear.
Old 06-10-14, 02:24 PM
mdhaliwal
mdhaliwal's Avatar
Sexy - what did it run you?
Old 06-10-14, 08:15 PM
mrpartsman
mrpartsman's Avatar
to make a correction here the calipers are not made by Stoptech, the complete brakes are made by Advics, and they are the OEM manufacture for Toyota and Lexus.
Old 06-10-14, 08:29 PM
sam430
sam430's Avatar
To me, the oem f sport brakes aren't that great. Go for aftermarket front.
Old 06-10-14, 09:17 PM
gotink
gotink's Avatar
Way to much miss info on this site to even begin to figure what is fact and fiction...I've must have seen half a dozen different makers of the lexus brakes I give up sorry if I was mistaken...
theboss252
12-05-16 11:11 AM
djpeakSD
05-31-12 12:01 PM
celicaxx
Suspension and Brakes
11-19-10 08:03 PM
The G Man
02-09-08 10:22 AM
bucs1985
10-18-07 01:17 PM
Quick Reply: Opinion on Brakes
