Any drifters?
you have to stop the car, put it in park and disable the VSC twice. the second time you have to hold it.
even after everything is off, you have to go pretty fast to break traction and start sliding. good luck, don't crash your car
Turn off all your traction control and do It on a track. When the car drift it will hold its gear the gs is easy to hold a drift since it's big have fun but do it on a track, more safe and less risk of messing up.
Traction will Turn back on every time I start the car.
Weight transfer, power over, etc
VSC and TRAC are handled by the same button to the left of the steering wheel. By pressing it once, it'll shut TRAC off. If you press and hold it for ~3 secs (while car is not moving) it'll shut TRAC as well as VSC off. TRAC alone automatically turns back on once you go over a certain speed limit (35mph I think) unless you had both off. Then they will stay off until you restart the car or press the button again.
There's a big roundabout in my community far from traffic and I've drifted around there twice, not hard to do. Trac & VSC off, S+ mode and shifter on M, go around the corner and punch the gas in 1st gear and you'll drift lol ... Be safe ...
