Need help with wiring for led headlight
So I ordered led hybrid headlights and need to know how to get the high beams to work when plugged into gs 350 f sport. I tried contacting the guy mshmsh but no luck on getting a response
The LED Headlight High Beam is just missing a ground (Pin 24). You can connect it with the ground from the low beam (Pin 9) or find a ground. FYI you will still get a warning light for the auto level. The only way to stop it is by getting the motor from the HID and tricking the computer. That's how i did my set up. Which version LED did you get? USDM or JDM (or other country)?
Here is a diagram i made its kinda messy. Oh i think i messed up on the numbering in the high and low but you will know which one is which.
![Need help with wiring for led headlight-led-diagram1.jpg](https://www.clublexus.com/forums/attachments/gs-4th-gen-2013-2020/338504d1461370835t-need-help-with-wiring-for-led-headlight-led-diagram1.jpg)
Here is the Auto Level Motor (HID). This motor (need 2 left and right) I used to trick the ECU
![Need help with wiring for led headlight-img_1848.jpg](https://www.clublexus.com/forums/attachments/gs-4th-gen-2013-2020/338501d1461370835t-need-help-with-wiring-for-led-headlight-img_1848.jpg)
Here is the difference between the USDM and JDM version. I have both
USDM has the amber turn signal in the corner
![Need help with wiring for led headlight-usdm.jpg](https://www.clublexus.com/forums/attachments/gs-4th-gen-2013-2020/338502d1461370835t-need-help-with-wiring-for-led-headlight-usdm.jpg)
JDM has no amber turn signal in the corner. It is a solid piece.
![Need help with wiring for led headlight-jdm.jpg](https://www.clublexus.com/forums/attachments/gs-4th-gen-2013-2020/338503d1461370835t-need-help-with-wiring-for-led-headlight-jdm.jpg)
FSport model cant read the AFS motor in the headlight. It won't even function. it will just stay in the same position. I'm not even sure if the AFS can move up and down. I have tried wiring in different ways but to no avial. Also I have a feeling the auto level is only in HID not LED. but i can be wrong.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
Attachment 338504
Attachment 338501
Attachment 338502
Attachment 338503
Attachment 338504
Attachment 338501
Attachment 338502
Attachment 338503
What i did is get a used left and right usdm non AFS headlight. its cheaper. motor alone is 400 and up.
