4GS Window Tint Master thread (pictures, products, issues - merged threads)
#168
Double pane isn't always a part of winter package. My 2014 Premium had double pane front windows and I'm here in SoCal and we don't have winter package or even AWD GS, there are maybe some but I've never seen one at the dealer, always RWD. My FSport has single pane now.
#171
Every vehicle I have ever had tinted windows on scratches at the top where the window goes up into the seal. It's not a big deal, lucky it's not the whole window scratching. I've had that happen numerous times.
#172
Yea me too. From my Corolla to Camry to Accord to GS all scratches on the top and they're all single pane. It is rubbing when u close it and there will always be dirt on that rubber strip, so unless u clean it 24/7, it'll show some scratches when it rubs. But maybe on the dual pane it rubs more due to the tighter space.
#173
I have ceramic tint on the double pane windows of my '13. No issues or scratches. I even have ceramic tint on my front windshield.
Whether or not the panels "need" to be removed depends on the design of the door. My installer told me the panels needed to be removed on the GS because there is no way to reliably slide the film in through the insulation of this model.
For what it's worth, I have never had a rattle or squeak issue after installation either.
#174
Not every tint shop will take apart your door or use a shim to pry apart your door seals to install tint. I had tints install with non of what you describe. I was standing right there when they installed my tints. All the tints were precut and they did a great job without taking apart doors. Dont make your bad experiance ruin tinting for you. Just find another installer.
#176
BUT, i kind of prefer the white on red contrast when driving. looks very sharp.
for now will let it be with no tints.
#177
I had Huper Optic Ceramic's installed, which were hand cut by the installer. I also was able to watch him perform the installation.
Door panels were taken off as he said he had to do. Either way door panels are coming off again for the F-Sport trim TSB.
I don't know if I have scratches up top, as I don't remember ever opening the windows.
#178
Just today I had Hüper Optik Ceramic window film installed on my newly acquired GS 350. The installer I use has been installing window film for 22 years and is excellent. 95% of the film they install is computer cut, in lieu of hand cut, so all pieces are precisely exact in terms of fit. The installer definitely took the door panels off my car - the guy that did the door panels used to work at the local Lexus dealership (largest in U.S.), so he knows what he's doing. Plus, this installer (team of 3-4 guys doing the work) is used to installing window film on all kinds of very high-end exotics (Ferrari. McLaren, Lambo, Maserati, etc.), so a Lexus GS 350 is plenty commonplace.
#179
#180
