Anyone got pictures on what they moved to get to the fronts.
You don't move anything for the passenger side. For the drivers side you move the washer tube and u can pop out the fuse box cover only not the whole box lol I was going to take out the fuse box though
Ur hand wouldn't fit if u wear gloves, that space is already super tight.
Let me know if anyone else having loose bulbs.
Latex gloves I mean not those thick ones. Will prevent cuts if anything the latex will cut ripped lol happen always gets stuck and I pull my hand out rips. Where you located fily?
Are they coming out, did you push them in for suction.
I have mechanic gloves but sure I won't be able to fit in there with those, sadly I don't have small enough hands. So will ask my friend.
Not sure why they made it rubbery suction to push it in they should've created the bulb to just twist it inside and good to go. Made stuff difficult. I took me awhile to push it in perfectly to make it secure and not loose.
