Anyone feel the headlights are factory adjusted too low?
#76
I turned it around 4 times, but I think I'll turn it a few more. Not as important since we have auto-high beam.
#77
Wow I thought it was just my bulbs going dull or something. I have remarked to others when driving that the HIDs in lexus are disappointing compared to previous cars I've owned. I had no idea lexus by default would have the beams pointing so low.
My car has adaptive headlights (2013 lux pkg)...just to verify, I can still do these same adjustments that were mentioned, right? Just no horizontal movements since that is apparently locked in the USA?
I just don't want to mess anything up with the adaptive aspect of the headlights.
#78
Yep, you can still make the same adjustments. I had the same car, made a big difference.
My LS is the same way, but it's much harder to adjust...
#79
EDIT / UPDATE I just confirmed on my '14 Lux what SW15LS confirmed, you can adjust up/down and left/right. Let's hope tomorrow I don't discover that I mucked up my beam alignment.
#80
Thank you both SW15 & spoogenet -- appreciate the responses.
I think I would like to focus on up/down first before going to left/right adjustments. I too am worried about screwing them up, but this is something I would eventually want to do. I say this because at times, when I drive around a corner:
- Swiveling back/return of headlights seems narrow on the surface in terms of where the beam rests at (I hope this makes sense...I am talking about when the adaptive lights "resetting" back to neutral after a turn)
- Quality and depth of light output just doesn't seem what I would expect...narrow view of sight, depth going forward seems shallow compared to previous cars
- if to characterize it, it's almost as if my headlights are "cross-eyed" in neutral position..
#81
#82
Hi, please, can you tell me if i must adjust bolt 1 and 3 or bolt 1 and 2? My car is european so I must turn bolt 2 or 3 the same number of turns and in the same direction as bolt 1, That's right?
My factroy adjusted is too low... If i turn it around 5 times It will be enough? Must I turn off AFS before the adjusment?
Thanks in advanced,
Pd. In my car I can´t see the 45º cutoff slope......
#83
Thanks in advanced,
Your adjustment procedure may be ***-backwards from U.S. models. I really do not know and any advice I'd give on a Euro model would be a total guess.
#84
I wish the owners manual had the same instructions as my IS has. The IS gives you measurements to where your beams should be pointing at a given distance. I had to adjust my IS 250 back in the day and I adjusted them to the manual. It made a big difference. I guess one could take those same instructions and just adjust them for the ride height of the headlamps on the GS. The IS instructions are located on the pdf here: https://www.clublexus.com/forums/is-...-uneven-2.html
I had to raise the headlights on my GS. I did 5 turns on the driver side and 4 turns on the passenger.
#85
With your car being a Euro model I believe the headlights are very different. I'm not sure if you'll have a 45° cutoff like U.S. models.
#86
Out of all the Lexus cars I've had through the years, the GS is the only one with the headlight issue. Same deal with my 2014 and now the 2019 is too low too! 3-4 turns clockwise is good. 5 is too high I think.
The ES and RC are fine and were adjusted at the proper height from the factory.
#88
