Anyone feel the headlights are factory adjusted too low?
#92
I’m so thankful I found this thread. I also thought my headlights were too low. I thought it was just me because it never crossed my mind they were set too low from the factory. 4 turns on each light made a world of difference. Now they seem normal.
#93
I've been happy with the factory aim of the headlights in all three of my GSs, but it seems as though I am in the minority. At least it's a pretty easy task to change.
#95
Let me update my part of this thread. I did 3x full 360 degrees turns and found that the headlights were still too low for my liking. I really noticed this when driving on a highway last night and my light beams were still way too short. I never really got a chance to drive at night since my last adjustment so I thought 3 turns were good enough but I was wrong! ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
So I did another 2 turns and will test it later tonight and see if it's high enough now. I will update again later.
#96
Forgot to update. I did mine last week and it makes a HUGE difference in night driving. Not really sure how many turns I did. I picked a mark on my garage wall and raised the light beam to that level.
It was not so easy to turn the adjusters with the screwdriver but finally got it done.
#97
Okay, so 5 turns were too high. I can see very well but I feel bad for the oncoming traffic. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
4x 360 degrees turns is the sweet spot for my 19 GS without triple-beams headlights.
#98
![](https://cimg9.ibsrv.net/gimg/www.clublexus.com-vbulletin/1024x768/regulacion_abb7c7e3ae1fd7847f79fac307378f140ec958a4.jpg)
Hi, please, can you tell me if i must adjust bolt 1 and 3 or bolt 1 and 2? My car is european so I must turn bolt 2 or 3 the same number of turns and in the same direction as bolt 1, That's right?
My car have Headlamps Led + afs + ahb
My factory adjusted is too low... If i turn it around 5 times It will be enough? Must I turn off AFS before the adjusment?
Thanks in advanced,
#99
On my 2019 with non triple-beam, #3 has nothing under the cover so nothing to adjust. 1 and 2 only, same turns, same direction.
Try 4 full 360 degrees turns first. I think 5 would be too high.
#100
![](https://cimg2.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/20210821_215738_d836c40e83c76fedf9039c7575c2b2a9382eae07.jpg)
My car is European 2014 GS-450h Luxury. I think with triple beam, right? So i must adjust 1 and 3 only, same turns, same direction. Is it correct?
#101
Thanks in advanced,
#103
That's right!
