Rear License Plate Screws
You might need to grab a flat head screw driver and put it underneath the lip of the screw. As you turn counter clockwise, make sure to lift up and it should come out of place. Hope this helps.
Originally Posted by marjenmill
The GS is shipped with masking tape over the license plate nuts and if the dealer just screwed the bolts in with the tape there instead of taking the tape off first, the screws will end up stripping.
Happened to me (dumb dealer).
They fixed mine - probably just re-tapped the holes.
Liquid Wrench should help or take it to the dealer. Once you get them off, put some anti-seize on the bolts before putting them in.
Was sure both methods would have done the trick.
The bolt just turns but doesn't lift no matter the pressure
Don't wanna spend 30 on the official vampliers.
What else do you guys recommend?
Got all the screws off except this last one and it's driving me nuts
Have you considered removing the trunk liner and getting to them from inside the trunk? There may be enough screw showing to push on it from inside the trunk while turning it.
The problem is that the cars themselves rust, the exposed screw threads are exposed steel and corrode hence the seizing.
Your best bet to get the screws out without snapping them off (And then you have to drill them out which is a real PITA, ask me how I know.. we have to do it 5+ times a month) is to soak them with Kroil.
Kroil is the best substance on earth to unfreeze rusted stuff. WD40, in comparison, is like using water. Take it from someone who works on antique cars!
To keep this from happening in the future I suggest squirting a drop of Kroil in there and coating the threads with some anti-seize paste.
Popped my trunk liner clips off and accessed the bolt behind the license plate.
Using two wrenches I was able to remove the stubborn rusted nut quite easily.
Finally got the old plate off.
Thanks guys
Thanks guys
Originally Posted by lamikela1
You should at least clear it away from the holes so that it does not clog up the screws. If not you may strip the screws if you have to remove them later.
Yeah, I don't know why but that tape is pretty tough. I guess they want to be sure that no water gets in there before delivery. I cleaned it off my other cars completely but you have to use an adhesive remover as it's really sticky stuff. I did not do that on my current Lexus.
