Life of front brake rotors F-Sport
#77
How many miles were you at when you changed yur rotors?
#79
I'm in the same boat needing rotors and reaching out to some major brake manufacturers and parts suppliers with no luck on aftermarket........yet. They are in the works.
L-SB-0100-16(see attachment below) is the latest Service Bulletin on these and appears they have new part numbers and added shims.They went back to 1 piece rotors.and added a shim between the hub and the knuckle....they are cheaper but more work as the wheel hub has to be removed, at least the first time changing over.
43512-WY010 and 43516-WY020 looks like the new part numbers. Confirm numbers and availabilty with your Lexus dealer of course.
There is another thread on this somewhere on the forum also.....
#80
Does anybody know the torque specs for the caliper bolts? I'm getting a creaking sound when I depress the brake pedal after a complete stop. I resurfaced my OEM rotors and I can only thing that I didn't torque the caliper bolts correctly. I saw a video by Dan on YT and it said 58 lbs and that's what I used.
LatinLS430 (08-27-17)
#83
I did a search and this thread shows 58 ft. lbs:
https://www.clublexus.com/forums/gs-...que-specs.html
Are the RWD F Sport calipers torqued more ?
Here's another one with the IS350 that seems to have them same brakes as our cars and they say 100 ft lbs.
https://www.clublexus.com/forums/sus...y-install.html
LatinLS430 (10-05-17)
#89
after i got the first out of stock notice from before i canceled the order.... it wasnt till about a week and a half ago i tried to see if they had it in stock - luckily they did.... only thing that it took about a week for them to ship it out....
