Life of front brake rotors F-Sport
#91
Installed ebc rotors.
Havnt gotten a chance to really drive to see how the feel, so far so good. Paired with stop tech sport pads.
I did seem seem to feel the extra 10 pounds in the steering - I think.
Oh yeah - there’s about a 5lb difference from stock rotors to ebc rotors.
#92
#93
#94
Pulled the stop tech pads after failing to cure the squeal. Cleaned the caliper, put noise grease (whatever u call it) on the shims and brake pads, sanded down the pads a bit - only thing I didn’t do was mess with the rotor.
But i switched to a akebono pad set I had (practically new) and squeal went away. Interesting enough - I had pulled the akebonos off because they squealed with the stock f sport rotors.
#96
Just installed my EBC 14in rotors on the front with Brembo Ceramic pads. So Far it's been good. Stops have been solid and short with no squeals or squeaks. Brake Feel is better than Factory Pads and also seem easier to modulate. The rotors are 1 piece and weigh 4-5 pounds heavier than the stock 2 piece rotor, but can't really tell the difference when you're driving. When the pads are broken in I'll report how they are holding up. BTW, I changed pads and had my front rotors machined in May 2016. I drive easily 12K-15K a year. Hopefully these Brembo Ceramic pads last longer than 18 months.
#97
#98
There was no Left or Right side motor marked on the rotors. I didn't notice if the vents were directional or not. I did notice that the non factory Brembo Brake pads I got from Tire Rack do squeal and squeak a lot when braking. Will be replacing these pads with factory pads within the next week or so.
#99
As for pads I have tried stop tech sport, akebonos and they both squeal when hard breaking or near the end of the breaking process. I too Plan to try the stock pads. If doesn’t work I just May pull the ebc rotors and resurface my stock rotors if I can.
#100
Three sets of brake pads update.
Pulled the ebc rotors as I have tried 3 different sets of brake pads - all new. 1. Stop tech sport. 2. Akebono. 3. Oem lexus. They all squealed with the ebc rotors. Not sure if material of the pads didn’t mix well or what. Calipers were cleaned and anti squeal lube was used every time.
Swapped the ebc rotors and put put back my oem rotors with the new oem pads - no squeals.
#101
Im having the hardest time finding front rotors for my 13 GS350 FSport RWD. Ive found plenty of pads and rotors for the AWD but nothing for the RWD. Any help would be appreciated. Thanks.
#102
there are big brake kits if you want to go that route.
#103
yea i found a pair of EBC but didnt know if it was true or not. Alot of these sites are misleading. might just go the OEM route.
#104
I'm headed that direction. I swapped in oem Lexus pads last saturday on the EBC rotors. During the test drive, squeezed and squealed like there's no tomorrow. So I've got the OEM 2pc rotors, OEM shims, and new poem pads on order and should be in this week. Hope to get them on some time next week. This 4th Gen Lexus GS F Sport is really finicky on brakes. I just think the because of the composition of the EBC rotors make it work better with EBC pads, which I remember reading on their website. But whatever it is, these EBC rotors work but, they squeal like crazy on OEM pads, Tirerack Brembo pads, Stoptech Sport pads, and Akebono pads. Hope this helps.
#105
I just had my front brakes done on my 2015 F Sport at the 30,000 mile service. New pads, machined rotors, etc. I decided just to make it easy and stick with oem Lexus on all the components. No squealing!
