Key Fob Battery Replacement
Old 02-27-17, 05:04 AM
Spideyman1
Spideyman1's Avatar
Originally Posted by dan87951
?.... The car will tell you when the battery is low -- look for the message on the instrument cluster when you shut the car off.
Does anyone know if this warning message is set at mileage intervals, like the scheduled service intervals, or does the vechicle actually sense a lower signal from the key FOB? I assume the latter, but wanted to check.
I know on my wife's 2011 RX, if the key FOB battery is totally dead, you remove the valet key and hold the FOB close to the start button, and the vehicle will start. I assume the GS' also have the ability?
Old 02-27-17, 05:33 AM
yardie876
yardie876's Avatar
You're correct, but you don't have to remove the valet key.
Spideyman1 (02-28-17)
Old 02-27-17, 07:25 AM
bclexus
bclexus's Avatar
Received 2,180 Likes on 1,562 Posts
Originally Posted by Voda48
Thanks, the $300 quote was apparently something else on the car. It was actually my mom's GX where the dealer quoted her $80 to replace the battery, I quickly Swapped batteries in both remotes with issue for about 9 total.
You're welcome. Glad you found the battery replacement easy...and inexpensive.
Old 02-27-17, 07:35 AM
bclexus
bclexus's Avatar
The 'Low Battery' warning in the instrument cluster for the key fob remote is based on the [low] signal strength from the key fob remote being below a threshold - it is not based on mileage.
If you happen to be caught with a dead key fob battery, you can just hold the [intact] key fob next to the Start button and it will start...but I would not wait for that to happen. It's too easy and inexpensive to not replace the batteries every couple of years.
marty99
09-25-13 10:24 AM
crmjr1
RX - 3rd Gen (2010-2015)
15
02-25-13 05:30 AM
matador250
02-27-11 07:51 PM
Voix
ES - 5th Gen (2007-2012)
02-16-08 06:04 PM
Quick Reply: Key Fob Battery Replacement
