Is it possible to...program my 2013 GS so seat warmers/heated wheel come on at start?
You think my setting is non-standard. Can it only be set by the dealer or a special App? I saw my dealer's tech reset the LPS settings to standard default...and I have not messed with the heated seats setting (even if I could).
The question was about a 2013. My 2013 does not have the Auto mode feature for my heated and ventilated seats like the 2014 model does. I can only assume that the 2013 model must be 'set' using the LPS settings either manually or auto, whereas the 2014 model can be set manually or Auto using the console control. See 2:10 in the attached YouTube video.
Video Link: https://www.youtube.com/watch?v=xSyRySM-iuU
For 2013 there's is an auto mode vs manual that can be set by the dealer or via the Carista app. . I turn that on and off with Carista. The auto seats will come on when in ECO mode and 37 degrees or less . What I can't figure out is how to get the car to remember they were on when I turn the car off. . I know is possible but not sure how.
I know its a different car but in the '13 LS the setting for the auto steering wheel heater is changed using the nav in the settings somewhere. I assume you have looked there but just in case you have not I would take a quick look.
-Joe
-Joe
They can set it to maintain the desired setting if you wish.
Nope. Doesn't work on my AWD GS350.
I've tried that. Even asked the tech guy at my dealership. He said, if I left the heated seats on when I turned the car off, they would come on when it was started the next time.
Not true. I just went out to my garage and tried it again. No dice. When I restart the car they revert to being off.
Anyway, thanks for the responses.
If you park in the garage it won't be cold enough.
My heated seats are on if I left them on when I turned off the car, no matter the driving mode. I do not drive in Eco mode. Hell its a hybrid. It's always in Eco mode if you ask me. lol The passanger seat does the same as well. It even turns on when there is noone in the passenger seat, if it was on when I turned the car off. I know this for a fact because I always have to turn it off after my girl has been riding with me. Also mine does auto adjust itself when I am driving.
Okay so my only option on my 13 is to have the dealer change it from the 3-2-1-Off to always on whatever setting I put it on?
Is there any sequence of buttons or holding down certain things that I could do to change it?
On a side note, I did a google search on this issue and it led me straight back to a thread from nearly three years ago and viola! I posted a message in that thread where I unequivocally stated that it did work for me. Doh!
I think my mind was pulling tricks on me. I probably hit the button and forgot I turned it on. It hasn't worked since then.
Today the temperature will be in the 40s, so no way to test the under 30 degrees theory.
