Changing the door welcome courtesy light.
#107
So here are some better pics now that I've had a chance to do some adjustments. I decided to adjust mine so that when the doors are fully open the logo is casting straight and not at the angle of the door (slanted). Hard to explain but hopefully looking at the pics you get what I'm saying.
In the picture above you can see the logo closest to you is straight and the one further back in the picture is slanted. I ended up adjusting it to sit like the back door logo.
#110
Thanks! It took a while for me to get them that way and I would still like to tweak them just a little bit but I don't want to go through the trouble at the moment. I'm sure my OCD will kick in again and I may adjust them.
#111
#114
I got mine in this afternoon and just installed them 15 mins ago. I actually started to adjust the direction on one of them and after about 2 minutes they turned off themselves. Also I noticed the projection assembly or whatever it's called gets kinda hot. I think that's why they have timer built into them I think.
you did a great job of aiming, I wonder which particular lights you purchased ?
#115
These are the ones I bought and the worked no problem.
#120
Sure. http://www.windfireauto.com/
I photoshopped the logo, and WindFireAuto printed it for me.
Tell them to re-use the image on order #3381. Below.
