So I put the stock suspension back, but now the rear looks funny
01-18-15, 06:43 PM
01-18-15, 06:53 PM
Quote:
Originally Posted by
bclexus
For comparison sake... Whatcha think?
All above are AWD pixs.
This is my car a year ago,
Compared to this,
01-18-15, 08:59 PM
not only is it much higher but it looks like the body of the car is tipping forward to me. Does not look balanced.
01-18-15, 09:22 PM
Its clearly at least 1" too high in the back...
01-18-15, 09:29 PM
yeah its def to high but if you already drove it around you should probably bring it back. Once you drive it backwards and drive a couple of miles it should settle, something else is wrong.
01-18-15, 10:07 PM
All those pics make my RWD looks lowered.
01-18-15, 10:18 PM
Make sure the springs are seated correctly in the perch of the shock absorber, if it is not seated correctly it will make it higher
01-18-15, 10:41 PM
Are you using stock alignment cones (rear)/top hats (fnt)?
01-18-15, 10:52 PM
This is where the GS belongs, this is why the wheel gap
01-19-15, 04:44 AM
Dukeaudio
Yep, everything is OEM.
01-19-15, 07:37 AM
Interesting. Just needs a set of Yosemite Sam mud-flaps, and you'll be ready for the mountain ranges!
But on a more serious note, I'd have someone look at that pronto!
01-19-15, 08:05 AM
Driver's side height consistent w/passenger's? Front looks just as affected...
01-19-15, 01:51 PM
Something is def wrong. It's likely that the rear spring is not seated correctly with the spring pads and/or the springs were put in upside down.
Keep us posted on what the issue is.
01-19-15, 03:43 PM
Dukeaudio
Yeah, the front seems ok. I think the front actually settled some, so it looks normal now. But the rear is still at 4' gap
Not sure if putting the springs upside would cause this problem, I think springs would still compress either way.
01-19-15, 04:09 PM
Look for the dots... Might be hard if they're dirty..
The spring should only work one way..
But if they are upside down, then anything is possible..
Joe Z
