Transmission Fluid - Change or Not? (Merged threads)
#152
I'm not sure what other OBD apps or dedicated OBD devices have available but they should probably be able to access it if they can access more maker specific PIDs.
#153
Absolutely correct!
Always find it entertaining when someone starts a thread about the transmission fluid and needing to be changed. Many chime in with oh yes it needs to be changed and nothing last forever. They have ZERO experience on transmissions especially Lexus transmissions. Than there are the conspiracy theorist who state Lexus says do not change the fluid knowing it will fail as soon as it gets out of warranty. If I believed this to be true I would sell my Lexus and never ever own one again.
My local Lexus Service manager who has 25 years experience working on Lexus vehicles and has been trained by Lexus said it never needs to be changed. He went to Detroit where the transmissions are made for training and asked what is the #1 cause of Lexus transmission failing. Their reply was the wrong level of fluid and the wrong fluid. Both of these are factors in one changing the fluid. I will save my money and never change the fluid and listen to the experts. Never changed the transmission fluid and never had one problem.
__________________
__________________
jptwo3 (12-02-22)
#154
Absolutely correct!
#155
Lexus USA have taken steps to make their cars cheaper to own, this is one of them. My manual states the transmission oil must be changed every 150000kms and it's optional at 75000km intervals, which aligns with older vehicles using similar running gear. Lexus USA have also spaced out the spark plug and diff oil changes, they're not the only manufacturer that have revised servicing requirements in order to bring down the cost of ownership. It's all about meeting the market. I prefer to err on the side of caution when it comes to maintaining fluids that allegedly last a 'lifetime.'
jptwo3 (12-02-22)
#156
I have to find it but the jdm manual for the 4gs has transmission fluid changes in the owner's service manual
#157
I am getting my data from my local Service Manager that has worked on Lexus's for 25 years everyday. Who has been trained at the Lexus transmission factory in Detroit. Please state your experience on Lexus's transmission. If you have more experience than I am changing mine. In the end it all come down to each his own.
Like most of us here I have no experience with transmission, just compilations of acquired data. I'm going to quote user alchemist from 2014 who had a sample sent from his 3GS transmission with 100000 miles.
So I sent a sample to Blackstone labs for analysis. Here is the result:
Their written analysis from Blackstone and breakdown below:
“We see lifetime oils a lot and the name can be very misleading. Since this fluid was the original fill, these metals are from the original break-in. Most of the metal is from new parts wearing in when the transmission was new and some of it is just normal accumulation over the last 100,000 miles. Now that this oil was changed, your next report should show some nice improvements as this stuff washes out. Your samples should look more like universal averages, which show typical wear after ~32K miles on the oil. No contamination was found. You are however, starting to lose viscosity at varying temperatures. Therefore, you changed at the appropriate time. Check back in 20,000 miles without draining."
Blackstone said ~150000km was the appropriate, scientifically based distance to have changed the oil by. I guess Lexus Australia (or more likely the Japanese factory) are on the money...it's almost as if they knew and put the 150K tranny service in my service booklet
#158
I simply do not believe in lifetime fluids.
I have been pulling wrenches for more than 50 years.
#159
Found this paper, it is unrelated to the fluid change but is a GREAT SAE paper on the transmission:
http://documents.epfl.ch/users/f/fr/...oyotaAA80E.pdf
#160
WOOT! found even more documents! Adding them here for my own reference:
https://drive.google.com/file/d/1AUQ...sdLGkBYKX/view
https://drive.google.com/file/d/1eg0...NkOqM-Kf1/view
https://drive.google.com/file/d/1Iix...YMq5EWthl/view
#161
From the 2014 Lexus GS service schedule:
Transmission/Transfer Case Inspect transmission/transfer case for signs of leakage. If you discover any leakage, have it repaired immediately by a qualified technician. Note: The transmission/transfer case and transmission fluid are a completely sealed unit. Therefore, periodic checks and replacement of the transmission fluid are not required, and there is no dipstick on the transmission. Any repairs that require adding or replacing fluid should be performed by a qualified technician following procedures in Lexus service and repair publications.
#162
Is Toyota WS a synthetic fluid? The word synthetic isn't on any part of the bottle and even my local toyota parts guy has doubts.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
#163
#164
WS isn't even synthetic.
