Chimes for no reason when exiting?
Old 02-23-15, 08:51 AM
sick21
sick21's Avatar
^^I agree with that.
Besides, I usually jump out when my car is still rolling lol
Old 02-23-15, 08:52 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,047 Likes on 662 Posts
Ghost Rider.
Old 02-23-15, 09:51 AM
thekhmer
thekhmer's Avatar
Mine does that also I was curious too, all Windows closed and still a chime
Also my memory seats sometimes reset itself I have a gate to open when I get home so I jump out of the car and go back in my seats are at the full all the way back and steering wheel up and all my presets don't work..it has happen a few times and it's annoying
Old 02-23-15, 10:19 AM
bclexus
bclexus's Avatar
Received 2,103 Likes on 1,498 Posts
Hey, I'm usually thrown off my horse before it stops!
Old 02-23-15, 11:03 AM
rijc99
rijc99's Avatar
I'm betting its that the door was open before shutting the car off.
Next time it chimes like that... push on the door switch once. The chime will go away.
Old 02-23-15, 11:11 AM
ItzFilyO
ItzFilyO's Avatar
But I've opened my door or let my passengers out before shutting off my engine and never hear a chime. The car was still in gear too.
Mine only chimes a few times when I step out of the car with the key while it's still running or in the ON position.
Old 02-23-15, 11:16 AM
rijc99
rijc99's Avatar
Mine only chimes a few times when I walk out of the car with the key while it's still runnin or in the ON position.
Try this... start the car... keep the driver door open... let the car do its check... once the check is done... shut off the car with the door open. That's the chime. Now push the door pin. It will stop.
The triple beep you hear when you walk out of the car while it's running is the car telling you it no longer detects the key.
Old 02-23-15, 11:20 AM
bclexus
bclexus's Avatar
Same here.
I forget if there is a chime alert/reminder to set the parking brake if it isn't set to do it automatically. That's all I could think of, other than the normal things like a door being ajar or window roof open.
Old 02-23-15, 11:24 AM
bclexus
bclexus's Avatar
The OP said that everything is 'closed up'.
Old 02-23-15, 11:27 AM
ItzFilyO
ItzFilyO's Avatar
It looks like time to make another video of my car. I'll call this one "The Chimes."
Old 02-23-15, 11:28 AM
rijc99
rijc99's Avatar
If the car is on, opening the door will not cause the chime.
Was the driver door open when you pushed the ignition button to turn the car off? Keep the DRIVER door open THEN turn the car off.
Old 02-23-15, 11:31 AM
rijc99
rijc99's Avatar
No, he said everything is "Closed up" in reference to a question whether his sunroof or window was open.
He said the chimes stops when he closes the door. Try not opening the door until the car is fully off. See if it still chimes.
Old 02-23-15, 11:35 AM
bclexus
bclexus's Avatar
This chime thread is driving me C-R-A-Z-Y!!! Where are my earplugs...
Old 02-23-15, 11:37 AM
ItzFilyO
ItzFilyO's Avatar
That's a chimp, they don't chime.
Old 02-23-15, 11:43 AM
bclexus
bclexus's Avatar
Quick Reply: Chimes for no reason when exiting?
