Whats your favorite discovered feature?
#196
Car is in reverse with foot on the brake,
While mirror button R was selected and my right mirror aimed down automatically, I used the arrows to adjust the endpoint for the tilt and remembers it. This doesn't effect the mirror's position while not in reverse.
While still in reverse, select mirror button L and use the arrows to aim the endpoint you prefer when backing up. I aimed the mirror downward like the right did automatically.
When you take the car out of reverse the mirrors return to their driving position. Only now when you put the car in reverse, both mirrors adjust to your specified downward locations, automatically.
I have yet to try setting different aims each for L and R to know if they can essentially be used as two presets.
The following 3 users liked this post by jayemko:
#197
I just discovered this is totally adjustable!
#198
■Linked mirror function when reversing
●When either “L” or “R” of the mirror select switch is selected, the outside rear view
mirrors will automatically angle downwards when the vehicle is reversing in order
to give a better view of the ground. To disable this function, select neither “L” nor
“R”.
“R”.
●If the mirror angle adjustment switch is operated while the linked mirror function is
in operation, the angle and position of the mirrors can be remembered, and the
mirrors will operate at the angle adjusted to the last time the linked mirror function
was operated.
However, because the mirrors move based on the angle they are in when the linked
mirror function is not operating, the mirror angle when the linked mirror function is
operating will also be changed if the mirrors are adjusted while the function is not
operating.
was operated.
operating.
Your preferred driving position (the position of the driver’s seat, steering
wheel and outside rear view mirrors) can be memorized and
recalled by pressing a button. It is also possible to set this function to
activate automatically when the doors are unlocked.
#199
What annoyed me about the F Sport is that I couldn't go from Sport Plus back to Sport S mode.
I turn the **** clockwise and it goes from Normal to Sport S. Turn it clockwise again and it goes to Sport Plus. Turn the **** counterclockwise and I hoped it would go one program backwards. Nope-goes from Sport Plus to Normal.
Then today while in Sport Plus, I turned the **** clockwise.
Success-turning the **** clockwise toggles between Sport S and Sport Plus.
#201
#203
#204
Never really paid attention much attention to the nav screen when on the highway, but I thought that it was cool how it shows the signs.
#205
#206
#207
Originally Posted by GregCanada
I assume it's 2014 or 2015? I never noticed that in my 13'
#208
#209
no, it works on bluetooth mode and app mode but you don't have to install any apps on the car. You might have to install chromecast on your phone - maybe.
then you can use the steering wheels to scroll back or forth, the youtube video. You will get only sound. You'll have to have a playlist though. You can create a playlist for yourself on youtube.
#210
If you look closely, you'll notice that all of the interior lights of a 2013+ are LED. Nice little feature knowing that you'll never have to change a bulb.
