Whats your favorite discovered feature?
#692
Seabone726 (03-19-20)
#693
Lots of folks have experienced this, but it makes me so happy every time:
In S and S+, when you hit the brakes hard in response to something unplanned or for an upcoming corner, the car downshifts and rev matches.
It then stays in that lower gear for many seconds, which aids in emergency braking if you need, or to return to the gas in the power band to accelerate through the turn or escape a situation.
It's just so well tuned and intuitive, automatic and seamless. Makes the car a blast to drive and improves its safety all at the same time.
Chaos236 (10-01-19)
#694
bob256k (09-19-19)
#695
The following 3 users liked this post by bob256k:
#696
Yes, it will change, not dramatically , but the transmission is a learning transmission, driving the card hard for a few days will make a difference. See page 6 of the attached PDF. You drive it hard and in sport+ it will adapt to your driving style and be more prone to downshift and hold gears longer than after several days of consistent driving.
signdetres (09-19-19)
#698
Pretty much every modern transmission has some "learning" capability to adapt the car's shifting to how its driven; it isn't just valve-bodies anymore.
and this isn't even touching how the ECU and TCU interact, and what learning capability is built in between those two devices, let alone all the rest of the computers built in the car.
Chaos236 (10-01-19)
#699
#700
page 5:
CONTROL SYSTEM ARCHITECTURE
The powertrain control system features a newly developed driving response and acceleration management system. In this system, a Model Driver decides drive power targets based upon the accelerator operation, and a Powertrain Manager (PTM) sorts them into an engine torque target and gear stage target. As a result, both engine and transmission play an actuatorlike role, dutifully realizing each target. The PTM also considers requests for drive power from other systems such as Vehicle Dynamics Integrated Management (VDIM), which contribute to improvements in vehicle safety as well as performance. Figure 5 shows the main differences between this control system and conventional control systems.
Figure
page 6:
Regarding the gear stage selection process during deceleration, the new powertrain control system achieves reduced operation frequency of the brake pedal by the driver and enhancement of reacceleration performance. This has been made possible by expanding both the Grade Logic and the Navigation based Artificial Intelligence (Navi-AI) shift control, which allow fine-tuned engine brake control. In other scenarios, when the driver exhibits sportier driving, acceleration and deceleration is enhanced by delaying upshifts to maintain higher engine speeds. Further, during t
Figure
page 6:
#701
https://trid.trb.org/view/664979
Sorry for the caps, just copy and pasting
DEVELOPMENT OF A SHIFT CONTROL SYSTEM (NAVIAI-SHIFT) FOR 5-SPEED AUTOMATIC TRANSMISSIONS USING INFORMATION FROM A VEHICLE NAVIGATION SYSTEM
The authors have developed a transmission control system called NAVIAI-SHIFT that controls 5-speed automatic transmissions by using road information from a navigation system. It has been in use in Toyota's new Mark II. This control system calculates the length and geometry of the street from the vehicle's current position to the next corner based on road information from the onboard navigation system. It then determines the optimum gear selection based on the above-mentioned information and road grade information, and associates the determination with the present running speed and driver's operating behavior so that the optimum gearshift control can be achieved. This paper describes the configuration, features and effect of the new automatic transmission control system that employs navigation information.Sorry for the caps, just copy and pasting
#702
page 5:
Figure
page 6:
Figure
page 6:
The following 3 users liked this post by 5nX37:
#704
