Luxury package: Sport vs Sport+
Old 03-17-15, 02:43 PM
kevinm123
kevinm123's Avatar
Default Luxury package: Sport vs Sport+
I can’t tell the difference between sport and sport+. The suspensions might be a tad stiffer, but I feel no difference at all in the steering feel. The steering doesn’t get any stiffer.
I’m thinking something might be wrong with my car. Before I ask Lexus to take a look, I would like some feedback from people that own the Luxury package
I have already read that in the F sport package, you can really tell the difference, but my question is specific to the Luxury package.
Old 03-17-15, 04:28 PM
jjscsix
jjscsix's Avatar
I definitely feel a difference in the transmission and suspension. I also feel a difference in the steering, but not as big of a difference.
Old 03-17-15, 05:15 PM
bclexus
bclexus's Avatar
Received 2,175 Likes on 1,558 Posts
I think you may be a bit confused about the difference between Sport and Sport+ variable drive modes.
Old 03-17-15, 05:25 PM
JDR76
JDR76's Avatar
Received 1,614 Likes on 1,030 Posts
On the IS, the differences (in steering, shifting, throttle) really occur between Norm and Sport modes. Sport + is pretty much the same as Sport, but with suspension changes. Is it not that way on the GS?
Old 03-17-15, 05:35 PM
bclexus
bclexus's Avatar
Yes...that's correct.
Old 03-17-15, 09:52 PM
fuddyduddy
fuddyduddy's Avatar
Sport+ mode in my car holds the suspension very steady around turns and the steering wheel requires more force to turn it.
Old 03-18-15, 06:59 AM
kevinm123
kevinm123's Avatar
can you elaborate please? Sport+ should have stiffer steering and suspensions as compared to sport. What's confusing about that?
Old 03-18-15, 12:08 PM
bclexus
bclexus's Avatar
I believe the only difference you should be detecting is that the suspension has stiffer dampening in Sport+ mode, which you said you might have detected...and you would be correct As for the steering - I believe the heavier steering feedback in Sport and Sport+ is the same, and you detected that there was no difference...and you would be correct. But, you then said; "I’m thinking something might be wrong with my car." And with that comment it prompted me to say; if you were looking for anything more or anything different between the Sport mode versus the Sport+ mode (from what you correctly detected) I think you may be a bit confused about the difference between Sport and Sport+ variable drive modes.
Old 03-18-15, 12:36 PM
rijc99
rijc99's Avatar
Sport changes the throttle response.
Sport+ is the Sport throttle response PLUS tightened shocks and rack n pinion. So you should feel a difference in the way the steering responds.
The steering feel is most noticeable on F Sport RWD because that is the model with VGRS. Without VGRS the Sport+ will dial back power steering boost but the rack gear ratio is still the same.
Old 03-18-15, 01:58 PM
bclexus
bclexus's Avatar
Forget about the F-Sport - because the topic is about a GS 350 Luxury Package and the difference(s) of Sport mode versus Sport+ mode. Also, forget about the engine throttle response and also the transmission shift characteristics because both Sport mode and Sport+ mode provide exactly the same for those two things. That said, the only things that remain are the suspension and the steering. We already know that only Sport+ mode changes the suspension. And, we already know that the Sport mode changes the steering response. All that said, the only question that remains to be answered is - in a Luxury Package GS 350 does Sport+ mode 'further' change the steering in some way (e.g. even heavier feel over what Sport mode provides or a change in ratio, etc.) beyond what the Sport mode already changes the steering?
Old 03-18-15, 02:17 PM
rijc99
rijc99's Avatar
Forget about the F-Sport - because the topic is about a GS 350 Luxury Package and Sport mode versus Sport+ mode. Also, forget about the engine throttle response and also the transmission shift characteristics because both Sport mode and Sport+ mode are exactly the same for those two things. That said, the only things that remain are the steering and the suspension. We already know that the Sport mode changes the steering response. And, we already know that Sport+ mode changes the suspension. All that said, the only question that remains to be answered is - in a Luxury Package GS 350 does Sport+ mode 'further' change the steering in some way beyond what the Sport mode already has changed the steering?
Sorry, when I said throttle response I was thinking of computer shift logic and input as one.
So yes Sport S changes the shift points and throttle response. The Sport S+ adds in changes to shocks and steering. Sport S does nothing to the steering settings. So there is no further change that occurs from Sport S to Sport S+ as THE change occurs at Sport S+.
Scroll down to the variable driving modes pop out.
http://www.lexus.com/models/GS/features#
Old 03-18-15, 02:30 PM
bclexus
bclexus's Avatar
Going to Sport mode does indeed change the steering response. The question is - does Sport+ mode 'further' change the steering in some way beyond what the Sport mode already has changed the steering?
Old 03-18-15, 02:31 PM
rijc99
rijc99's Avatar
Not according to Lexus
Old 03-18-15, 02:33 PM
XFactor7
XFactor7's Avatar
It seems so unless I'm mis-interpreting what that link says.
Here's what Lexus says (from the link provided by rijc99 a couple posts above):
Sport S/S+ Mode
Sport S mode changes the gauge cluster lighting to a fiery red and alters the powertrain for faster gear changes and more dynamic throttle mapping. Available Sport S+ mode goes a step further by also tightening the suspension and increasing steering response. In both modes, the transmission's shift points are automatically altered coming into and out of corners for sharper acceleration.
Old 03-18-15, 02:37 PM
rijc99
rijc99's Avatar
Sport S/S+ Mode
Exactly, according to Lexus... there is no change in steering setting from Normal to Sport S. The change takes place from S to S+
Quick Reply: Luxury package: Sport vs Sport+
