iPod 5th Gen & GS350 compatability
![Arrow](https://www.clublexus.com/forums/images/icons/icon2.gif)
Has anyone tried to use an iPod touch 5th generation in their 2013 GS350 non-ML?
I know that it will work via the headphone port & Bluetooth?, but I'd like to use it with the USB instead.
Also, anyone's opinions on how it sounds via BT vs. USB vs. AUX.??
GS350Dat
Can you let me know which version of I-Tunes you are using? Also which music format are you using? I used "WAV" and "MP3" and using the USB connection the iPod Classic does not power up on its own after I switch off the engine and starting the car. Therefore every time I start the engine, I have to unplug and plug the USB. It has been very frustrating.
I have an iPod Touch latest gen with the front and rear camera. It works fine on USB.
I mainly use an iPad mini ret attached with USB running either Downcast or iTunes radio.
The cup holder when open is a perfect holding spot for the iPad mini. Perfect angle. Kinda like a smaller version of Tesla S's screen.
Sorry for the late reply. I just started using the classics probably since early this year and yes at the beginning there where frenquent drop outs! Meaning like someone mentioned you would have to unplug usb and replug it. Then it will work and yes very frustrating! Also when you try to switch songs you get a message that says iPod is syncing to system please wait. Or something rather! But as of late i started to do a "on the go"playlist and since then it hasn't have any problems. Maybe its that or maybe the car is adjusting to the iPod and probably works itself out! I also can switch songs instantly with out that please wait message. I sure hope that answers some of you alls questions!
Oh and i am using the current software for it! Good luck folks!
I will try the "on the go" approach and hope it works!
