Hey OhFace I see you blacked out your window trim as did I. I used 3M graphics and I am having a slight shrinkage at the edge now which has begun to show silver trim. Do you have a similar issue? What did you use? Thanks
Yes it has started with me unfortunatley. I was warned it might happen before I did it because there is no gap between the rubber and window chrome. Therefore no where to tuck the vinyl causing the expansion and shrinkage when it gets hot and cold. Mine are slivers but you can't see it from 10 feet away but up close its very annoying. Might just take it off other option is Plasti Dip. Just gonna hold out for now to see if it gets worse
