Battery dead, no manual key. Suggestions?
Bought my car used. No second key. Car battery is dead. Went to use the slide out key and the key is blank (hasn't been cut). How do I get in my car? Haha
Key fob is good, even put in new battery. Car battery has to be dead, security light is blinking very dim. I'm assuming the manual key is blank since there are no "teeth". All lines on the key are smooth. I don't have the key number tag thing.
Can they still cut my key for me? Can a locksmith break into my car without damaging it?
Ideas? Of course this would happen to me on a holiday weekend, haha. dammit
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Ideas? Of course this would happen to me on a holiday weekend, haha. dammit![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I would get a battery charger and let it charge for a few hours and you should be good. Happen to me during winter in my garage couldn't even push the car out because my electronic brakes were on. So that's the only option
Either way its going involve a locksmith is my point...
Call your local Lexus dealership and explain the situation. Certainly they have dealt with this before. Maybe they will have a solution that works out best for you.
I don't think modern car can be slim jim'd. They all use electronic actuators.
What they will do is slip a small air bag between the door frame and door... Inflate it to get a little space then try to hit the lock release. I would avoid this if at all possible because sometimes the air bag can create a permanent bend to the door.
Wait for the dealer to make a key or break out the little window in the rear doors.
Locksmith will be cheaper than brick+window. Don't think Lexus will make you a key without proof of ownership, unless you bought it from a dealer. The fact that your key fob has an uncut metal key tells me the previous owner sold or lost both sets of keys that came with the car. Did you look to see if the spare/tools/lug nut key are still in the trunk? I know hard to do that right now, just thinking ahead.
