How to identify 4GS options, with pictures
Latonka (05-19-20)
Thanks.
Remaining questions that need answers:
If the car has Lane Keep Assist, does that mean it has Departure Warning System?
If the car has Radar Cruise Control, does it mean it also has Pre-Crash Sys w/Pre-Brake and Driver's Eye Monitor?
Hube mentioned "Brake Assist". Is that an option? If so, what does it do and how to identify?
I asked Stormforge who is the OP of the FAQ thread, but he hasn't done it. Not sure if he will. If some of you PM him, maybe he'll add it.
https://www.clublexus.com/forums/gs-...ere-first.html
Read more: Toyota Global - Safety Technology - Brake Assist
Rear-wheel steering:
lexus4jess (01-24-21)
Thanks.
As to the PCS, the driver eye monitor above the steering column and radar system are components of the same system that monitors the distance to the vehicle ahead and where the driver is looking. Based on inputs from these sensors, it determines how fast the car should be going, or if breaking is necessary, or if the an alert should be sent to the driver, or if the car should be prepared for a collision. This is a single system, so it's all one option. The pre-collision part is on, even if the cruise control is not on, though there is a switch to disable PCS.
On a different note (earlier post), about the rear seat heater controls, the luxury package is available with the rear seat heaters, or without - about $450 difference, IIRC. At least that was the case in my model year. As you can see from my signature block, I got just about all the options, except the ML and the HUD - I ordered, and waited 4 months for the car.
