Help removing front grill emblem.
okay so I removed mine to paint them... you will need a tool that is blade thin... i actually used a pocket knife which i covered with a towel, to make sure i dont leave and scratches... be VERY careful and patient and it will be off easy.
I have also seen a tutorial of people using floss ... yes i mean dental floss to get under the emblem and basically move it as if your flossing behind it to separate the adhesive from the car body. this second option seems much safer but the first worked for me just fine
Good Luck!
Good Luck!
NormandyIS
02-13-13 11:55 AM
